ok, no improvement in fuel consumption with new o2 sensor
was reading on another forum that
before i was gettin like 300, until i replaced the charcole canister.. seems to better now..
could this help?
i believe my charcole canister is unhooked
  • 1 month later...
ok, have replaced my o2 sensor with the ngk one for an r33 gts-t
part number 0ZA395E2AB
no difference to economy so far :yes:
what else can cause poor fuel economy
i dont get more than 300ks a tank from a 200rwkw gts-t (via usual mods, powerfc etc)
Changing the O2 sensor alone when you have a PowerFC won't really help. As cubes said, chuck it on the dyno and get your low RPM and low load cells checked out. Try get the tuner to tune them as close to 14.7:1 as he can, and then let the PowerFC O2 feedback do the rest.
  • 3 weeks later...
  • 2 months later...
Does anyone have a yes/no answer as to whether a O2 sensor from an R33 GTST will fit and work on an R33 GTR? It doesnt matter about plug type i just want to know whether it fits in the thread and works with the computer, an answer would be greatly appreciated.
Cheers
ayone got an answer for the above?
  • 4 weeks later...
  • 5 weeks later...
  • 3 weeks later...
Pic of what I did with the stock plug and an EL Falcon oxygen sensor:
Btw NGK have a direct replacement for the RB25DET engine. Part Number OZA395-E2. ~$125 - $145 from repco
Needs some heat shrink around the individual wires will do that tonite.
  • 1 month later...
just purchased this earlier today and installed it/took it for a drive earlier and it seems to fixed a few issues i had. 1/ doesnt seem to hunt on idle anymore 2/ it now boosts better then before 3/ it rev's more freely. at the same time, i changed my fuel filter which i think assisted with the change in characteristics
ok, let me correct no. 2
i use to have a kinda surge feeling when i boosted it. it would only boost to about .1 bar when the accelerator was flattened and just feel like its lost all power and then pick up again. makes it feel really bad and kinda like its cutting out and then boosting again - if that makes sense. now however, it boosts fine and feels like it pulls harder. i drive the thing so i would know the before and after effects. but having said that, technically wouldnt a working o2 sensor help the ecu adjust its a/f ratio when boosting?
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
