After reading this forum and being new to a owning a skyline...... I have tracked down a direct replacement for an RB25DET motor from repco and is only costing me $90. Part is:
OZA395-E2 made by NTK (not NGK) - Part fits N14 Pulsar's etc...but apparently will do the same job for the RB25DET, more reliable than a cheap $60 Ford EL sensor where you neet to cut wires etc.
Can someone back up my story? Looking for others who have heard the same thing.
Christian
NGK's OZA395-E2 is a direct fit for rb25det
NGK's OTD2F-P1P is a direct fit for R32 rb26det rear sensor, and will work for front sensor if you attach the original plug.
both are nice and cheap and easily available
  • 4 weeks later...
The OZA395-E2 is NOT a direct replacement, the connection does not match, at least for the R34 GTT, not sure about 33's.
If anyone has a direct fit that i dont have to buy from nissan for a billion dollars, please post it.
NGK's OZA395-E2 is a direct fit for rb25det......
Sorry I assumed 34 is the same as 33...it fits OK in a 33 and S1 Stagea
Ok, after some deliberation I had come to the question:
What the hell is the difference between the O2 sensors???? Is it just the wiring and plug shapes?
This is a list of the parts I've found so far - havn't decided what to get yet tho.
Replacements for RB25 (mainly using the fact that EL parts are used)
From Repco:
NTK OZA395-E2 - which is now relisted as BOSCH 2269013007 (this part quoted $129)
ACA ROX-207
SUPER CHEAP:
OX1016 (not sure of brand - is the equivalent EL part)
For RB20
NISSAN:
22690-73L11 (quoted approx $200)
Someone previously said that the RB25 parts are usable on RB20 - which is what I'm looking for - is this correct????
I'm thinking of going to Repco this arvo and trying the BOSCH part. Still - was actually hoping for a part <$100
Edited by Anakha
Well....
There are only 2 types of 02 sensors - Titania and Zirconia. The Zirconia ones come in 2 thread sizes.
From there....the only difference is the plug. So there are 3 generic ones without plugs to chose from, or direct fit with a plug on the end there are hundreds to choose from.
To work out which generic ones we need to know thread size and titania or zirconia for each of the motors, then work out 02 snesors from who are which. But for that we need someone on the inside who knows what the part numbers mean.
  • 1 month later...
Summery....................
These are my findings so far,
NGK OZA395-E2 (This comes as BOSH now part number 2269013007) $129 from REPCO
ACA ROX207 (Direct fitment for Ford EL)
ACA ROX203 (Universal fittment)
NIssan Orginal Part Numbers for R33 RB25DE NON TURBO models-
Buid Date ( 93/08 - 95/01) Part Number - 22690 - 73L11
( 95/01 - 96/01) Part Number - 22690 - 85T00
( 96/01 - ) Same as above
By the way gary "Sydneykid" advised me to use ACA ROX203 for my car......think I should give it a go and see, If the original Nissan one is not that expensive ill go for it.
Cheers
Chinthana
  • 3 weeks later...
to add to post #521, here are other part numbers from fast:
R32
RB20DE (also same for A31, C33):
22690-72L00
RB20DET/RB25DE (also same for A31/C33 RB20DET/RB25DE, C34 93/03-94/09 RB20DE/RB25DE)
22690-73L11
RB26DETT All:
22690-05U21
R33
RB25DET
22690-21U00 - 93/08-93/11
22690-83T10 - 93/11-97/11 (Same as RB25DET in: C34 94/01+, WC34 96/09-97/08)
22690-83T11 - 97/11+ (Same as RB25DET in: WC34 97/08-98/08, Y33 97/06+, JPY33 97/10+)
RB26DETT:
22690-24U00 - 95/01+ (Same as RB26DETT in: R34 99/01+, AWC34 97/11+)
R34
RB20DE/RB25DE/RB25DET:
22690-AA005 - 98/05+ (Same as RB20DE/RB25DE/RB25DET in C35 98/09+, WC34 98/08+, and RB25DET in Y34 99/06+)
22690-AA007 is listed as alternate for above
RB26DETT:
22690-24U00 - 99/01+ (Same as RB26DETT in: R33 95/01+, AWC34 97/11+)
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
it will occasionally, eg when coasting in gear with no throttle (depending on car/ecu it will cut injectors - ie max lean)
even just normal lean deceleration may be enough to get it that low (ie even without cutting injectors)
only be concerned if its always 0.0...if it moves around, no problems
  • 3 weeks later...
Sorry if this question has been asked before but couldnt find....
Do R34 use the same o2 sensor as R33?
Or can some one tell me which to buy for an R34 (non genuine)
an answer would be appreciated please!!! im sick of waisting money on fuel
Edited by Malz34
From what I gather, the RB25DET Neo engines use the NGK/NTK Part#OZA395-E2 oxy sensor (approx $78+gst). Don't even have to replace plugs, this babies come ready to plug and play. I'm trying to source an oxy socket (with difficulty) to replace my S2 Stagea O2 sensor this weekend. If I can't find a socket I'll have to try a wrench/spanner/teeth to get the old one out.
EDIT: Unfortunately I told a lie, tried it myself and the plug definitely does not fit the RB25DET Neo, sorry. Might have to cut and crimp wires.
Edited by webng
Bloody Hell. This is page 28 of this thread. Taken me hours to read.
After page 2, I felt I knew what to get in the way of an aftermarket Oxygen Sensor.
Now, at page 28, I HAVE NO IDEA WHATEVER.
Can ANYONE, who has actually done it, on a 1992 R32 GTSt , RB20DET Engine (and Nothing Else ), tell me what they used, and which had the right thread and three wires, 2 of one colour, and 1 of another. AND IT WORKED. PLEASE??.. Just that answer. I don't care what else it fits, or what size spanner to use. PLEASE??
Am I right to say that RB26DETT uses Titania O2 sensors and RB25DET use Zirconia? The Ford EL O2 sensor that seems to fit with some wire crimping is a Zirconia type. ACA ROX207 which is similar with NTK OZA395-E2 but without the plug. Or have I gone completely nuts?
Its often a good idea to check out the traders section to see what they have to offer for our skylines. :)
http://www.skylinesaustralia.com/forums/in...howtopic=135194
Nissan Skyline R32 GTS-t, GTS-4: $88ea (Zirconia)
Nissan Skyline R33 GTS25-t: $88ea (Zirconia)
Nissan Skyline R32 GTR: $143, single, (Titania)
Nissan Skyline R32 GTR: $286, pair, (Titania)
Nissan Silvia/200SX S13/14/15 (SR20DET Engine): $143, single, (NFI, likely Zirconia)
Cheers Cubes for clarifying.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
