If you took off the dump, you should replace all the turbo --> dump studs given the level of heat they are exposed too. Did you replace the gasket?
Also, remember to reset your ECU.
Its probably worth giving the sensor a good dose of Penetrene or something similar to try and loosen the thread... I would have thought a combination of socket + universal joint + extensions and maybe a breaker bar on the rathchet, would have gotten it off.
For the record, IIRC the R32 GT-R sensors require a 17mm socket/spanner. I think Wilch indicated earlier that the EL one was a 21mm: was there much play in the 22mm Gordon?
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1377989
Gasket is copper and looked to be in good condition, so left it. It probably should be replaced, but I am pulling the current turbo off and replacing it all in a couple of months anyhow.
22mm is perfect fit.. 21mm is too small.
well for the record, I think it has done sweet F.A. for my fuel consumption.. just last day 8L for 50km (16L/100km ) which is on par as previously.. Reset the ECU too. We'll see how it goes over time.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1378747
What about the Heat sensor on the cat. does it play a similiar role to the O2 sensor? If thhe heat sensor is removed what could be the consequences?
That has already been done to death earlier in this thread. The sensor in the cat does not affect fuel mixtures: its merely to warn you that the cat is fscking hot and not to go parking on a flammable surface.
LW.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1400957
I just changed my O2 sensor today. When I was removing the old one, I realised the previous owner must have changed it b4, cos it had 2 white wires & 1 black wire, & was the Bosch brand.
Upon removal, the O2 sensor looked really crapped. Replaced it with the new EL O2 sensor, which happened to have 2 white wires & 1 black too. I have resetted the ECU... let's hope the fuel economy gets better!
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1413317
Sorry the format is so cruddy. Anyone know if I can use a table? HTML tags don't seem to do any good.
Try cut and pasting it to an editor that recognises tabs. It's easier to read.
Nissan Part numbers for front oxygen sensors (flat 3 pin plug)
Part Number Engine Applicable dates
22690-05U21 RB26DTT 8908-9108
RB26DETT 9108-
22690-17B00 RB20E 8905-9108
22690-01P00 RB20E 9108 -
22690-27M00 CA18I 8905-
22690-72L00 RB20D 8905-9108
RB20DE 9108-
22690-73L11 RB20DT 8905-9108
RB25DE 9108-
RB20DET 9108-
Nissan part number for rear oxygen sensor (square 4 pin plug)
22690-05U22 RB26DTT 8908-9108
RB26DETT 9108-
A front oxygen sensor (probably original) from a RB26DTT had the following details:
Approx 46cm from the gasket to the end of the plastic plug, NTK D2F printed on the sensor,
3483 stamped on the sensor nut
A rear oxygen sensor (probably original) from a RB26DTT had the following details:
Approx 50cm from the gasket to the end of the plastic plug, NTK D2F printed on the sensor,
35F8 (possible 35F3) stamped on the sensor nut
The number stamped on the nut is probably a batch number.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1415851
OK. Here are some more numbers and facts. Please correct if necessary - and this is ONLY for the R32 GTR.
The Nissan part number for the front O2 sensor is 22690-05U21 ($253.85 from Nissan)
The Nissan part number for the rear O2 sensor is 22690-05U22 ($271.70 from Nissan).
My front O2 sensor has a length of approx 56cm, and has a flat 3 pin plug with 3 used
My rear O2 sensor has a length of approx 46cm, and has a square 4 pin plug with 3 used
(Note that these lengths are different to the post above, but I estimated, the other guy measured)
Both sensors have a black, a red and a white wire. That combination of wires appears to only happen with Titania based plugs.
With Titania plugs:
Black is Reference (Out)
Red is Reference (In) and Heater (+)
White is Heater (-)
Output is 0 to 1 volts.
Titania plugs are NOT compatible with Zirconia plugs (ie do not substitute a plug with 2 whites and a black).
If you use the the NLMS Developments diagnostic cable, the front sensor is called O2 sensor, and the rear one is called O2 sensor RH.
Ocean bought an NTK O2 sensor, part number OTD2F-2B, which only has a cable length of 28cm. Ocean says he used it as a direct replacement of the front sensor (right plug and right thread, only shorter), but the harness had to be untaped and moved a bit to take advantage of some slack, and it wasn't routed as neatly because the original was a lot longer. He didn't have an issue with the rear sensor (square plug) because he spliced the wires which made it longer.
Has anyone managed to identify sensors with the right lengths and the plugs fitted?
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1415869
ah ****, the el falcon o2 sensor I bought was red black and white, so I assumed that red and black were heater + and - and the white was for the sensor.
I connected it to the old plug red - white black - white white - black
would this have damaged it? would reversing the colours to how they should be black,white - white and red - black make it work?
As when I replaced it I noticed no improvement in fuel economy
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1418682
GTaaargh:  What exactly is the point you are trying to make?
Lucien.
Lucien,
I've been reading threads about O2 sensors over the last couple of weeks, and visited a lot of web sites. I've seen a lot of opinions and gathered a small number of facts - such as the actual Nissan part numbers. I figured it was no good just having them on my scribble pad, I may as well write them all down in the one spot to help others searching for the same facts.
As to where I want to end up: I want to find sensors that are 100% compatible (correct type, colour of wiring, length and plug shape) with the front and back R32 GTR O2 sensors, and maybe some of the others models. I also want to clear up the issue of Titania and Zirconia sensors as fitting the wrong one will do no good at all.
As I get more info I'll add it.
BTW - if anyone finds an exact replacement part, let me know. Also, if anyone can tell me the markings on the sensors and the cable lengths of Nissan non R32 GTR sensors, I'd appreciate it.
James
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1419030
Well, check this site: Lambda sensor shop and click on the Wire Colours 2 link. If they're right (please correct me if you know otherwise) a black/white/white sensor is Zirconia, and a red/black/white is Titania. They are incompatible, no matter how you connect the wires.
The rest of the site is pretty good too.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1419068
Well I just connected the red of the nissan plug to the black, and the white and black to the two whites of the NGK plug. I assume I got it right as it seems to work?
still not noticing massive difference in fuel economy.. did advance timing somewhat, which seems to have made more of a difference. Down to about 13L/100km.. from about 15L/100km which I guess is better than nothing. Bit poor for a nearly stock R32 though :rofl:
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1419400
To quote the page:
1. Count the number of wires on the original sensor.
2. Check the colour of the wires
  a. If the sensor has black, grey, purple or white wires, it will be a Zirconia sensor.
  b. If the sensor has one red wire with the possible exception of some Japanese vehicles, it will be a Titania sensor.
3. If it is a Titania sensor then check the original thread size of the sensor.
4. If you have ant doubt or query, please contact us.
Now, going by the page you linked, looking under Skyline (http://www.lambdasensor.com/main/skyline.htm) they say:
A sensor we are often asked for, is one to fit the Nissan Skyline Import. After much work we have found a Bosch sensor that we think fits the bill. Several customers have purchased these with good results.
Picture above shows the plug arrangement.  Wire length is 10.5 inches - 270mm.
Edit: Also notice that the sensor they picture does not have any red wires.
Perhaps just email them and ask which Bosch they suggest?
Lucien.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1419739
I recently bought my R33 4door auto. Driving it 370 kms home it used 3/4 of a tank.
i got abit of round town driving on the last 1/4 and fuel used was 430 km for 52 ltrs.
i think thats 12.3 ish ltrs / 100 km .... also filled up this weekend, and absolutly babying it round and its done 55kms for 1/4 tank !
So onto dyno today to check it as i have to drive to brisbane tomorrow.
Turned out it was cruising at 11.5:1 AFR !!! The Dynolog dyno can read the nissan codes directly, and the short and long term fuel trims were set max.
So a new O2 sensor and voila, 14.5:1 afr cruise now.
Hopefully i'll get over 500 kms to the tank now (close to 50 litrs as i fill just as the empty light comes on!)
I'll post results next week.
Oh car is stock save for a unshielded pod, and 3" dump and cat back. Cat is a highflow guts by the looks of it, but its a 2.5" in / out "REDBACK" cat .... compliance cat if im correct ????
Gary.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1421007
To quote the page:
Lucien.
OK. I'm only interested in the R32 GTRs. However, according to NTK site the same sensor is used by the VL Non-Turbo and Turbo Dunnydoor, and the R31 Skyline.
The NTK sensors for the R32 GTRs have D2F stamped on them.
One sensor that has been used for GTRs is OTD2F-2B (right plug, right sensor, short cable). The O means Oxygen. The T means Tatania.
The Falcon EA through EL uses a OZA23-D2 (iaw the site). The Z means Zirconia.
So, IMHO, do not use the Falcon sensor for the R32 GTR, R31 or VL Dunnydore.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/4/#findComment-1426150
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
