Hey everyone, I had 03 350GT and it has traveled near to 50.000kms now, and these are the lists I need to do :
❏ Replace engine oil and filter
❏ Lubricate all locks/hinges
❏ Replace automatic transmission fluid
❏ Replace climate controlled seat filter (M45/M35/Q45, if so equipped)
❏ Replace differential oil
❏ Replace engine air filter
❏ Replace engine coolant/flush system
❏ Replace engine drive belts
❏ Replace in-cabin microfilter
❏ Replace manual transmission oil
❏ Replace radiator cap
❏ Replace transfer case oil (4WD/AWD)
❏ Replace wiper blades
❏ Rotate tires (except G35 Coupe, Sport)
❏ Optional: flush automatic transmission (flush with ATF)
❏ Inspect the following:
__ All lights
__ Axle & suspension parts
__ Brake lines & cables
__ Brake calipers, pads, rotors
__ Brake light & cruise control
switches2
__ Drive shaft boots (4WD/AWD)
__ Exhaust system
__ Front suspension ball joints
__ Fuel lines/connections
__ Fuel tank vapor vent system hoses
__ Headlights/adjust if necessary
__ Propeller shaft (4WD/AWD)
__ Steering gear and linkage
__ Steering linkage ball joints
I am going to DIY for some jobs on the list , and in regards of air filter, has anyone use the A360 from repco , if yes, please let me know if there is any downside about it (acceleration / power wise) ? As it's $13.88 compared to $89.00 KN air filter.
Thanks
I have used one, no issues with it.. I think any power differences with a K&N would be very minimal, if any at all. Most people buy K&N because they can be cleaned and reused.
Most people buy K+N because they are retarded and don't realise it will coat their AFM with a film of oil, causing it to meter air incorrectly.
Go with the Ryco paper element, or if you want a free flowing filter, a Blitz or similar dry cotton.
Thanks a lot for the input guys. Highly appreciated it. Time to pay visit to Repco tomorrow
Do you know who stocks these blitz filters, or know the right part number? I need a new filter and was going to buy a K&N until i saw this.
http://justjap.com/store/product.php?productid=18674&cat=272&page=2
They are available cheaper but shipping may blow the price out.
http://www.frsport.com/SUS-Power-LM-Panel-Filter-Replacement-Infiniti-G35_p_13154.html
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
