RB30E extractors suit R31 skyline. Not sure of type, but they seem to be exactly the same ones as in my car as well (Nissan??) which sound pretty good.
They are 6 into 2 into 1 and the pipe back to the cat. Should only take an hour or so to bolt up (really easy) and give you a nicer exhaust note, and a decent power increase.
Seem to be in pretty good condition with no obvious cracks, dents or problems. You can probably sand them back a bit and will come up fairly nicely if you care about the look of them.
Brisbane or goldcoast or post i guess, but only if aussie post will send it (probably too large).
Asking $100. PM me, or call or SMS 0417 016 326
https://www.sau.com.au/forums/topic/43098-rb30e-extractors-bris/
    • Lowest point on the car is 105mm now, so just legal and hopefully high enough to clear After paint, much happier with how it looks Before looked real 😝
    • I'll measure it up at the lowest point later and post it up Currently painting, with the oven all warmed up to 93°c
    • How much clearance is under the car? We have speed humps being added everywhere around me. Faster than they fix the potholes, thats for sure.
    • After some googling of various websites IRT the best ride height for correct geometry I ended up going,  hub to guard, 330mm in the rear and 345 at the front, these heights came from Flyin' Miata in the states as what they recommend (13" rear, 13.5" front) The rear needed to only come up 5mm, but the front came up 15mm Overall it is around a 25mm drop from OEM ride height, doesn't look all 4x4, and hopefully should be enough height to clear those pesky speed humps I have lost around 0.5° camber on the front, and around 0.2° in the rear, I have no idea about what it did to toe settings so I'll look at a new alignment next week to get it set up how I want, zero rear and a little in at the front I've also stripped the new intake and am currently cleaning and preparing the alloy for some paint, I've headed into work to do it as I can use the ovens in the soils lab to cure the wrinkle paint at 90°c Jackie has banned me from using the oven at home for stuff like this....🤣
