G'day all,
I know, it's completely out of place in a Skyline-enthusiasts forum but I'm gonna try my luck anyway.
Up for sale is my 2006 Honda Civic (in Royal Ruby Red)
Swapping for : R34 GTT or GT (Manual) , preferably with service history/logs available
Cash your way depending on overall condition.
For swaps, an independent mechanic will be called in.
or
Going Price : $10,300 , exclusive of RWC (but I can arrange it for you busy folks :no: )
Frankly, I would prefer the swap; my interest and time on the forums here would be wasted otherwise :P
General Details :
i) Second owner, purchased October 2012 at Doncaster Honda
ii) Manufacturer's warranty valid till 1 Feb 2014
iii) Full service history/log books
iv) Regularly serviced every 5000km at Honda only ; 50,000km service done in April 2013.
v) Mechanically faultless
vi) Interior is immaculate; car used by single driver as a daily (mainly on the M1).
vii) Registration valid till mid March 2014.
vii) No accident history, ODO'S AT 51,106kms.
Body Flaws
- Doors have been keyed on both sides (has just been removed via cut and polish; photos soon!)
- Bonnet has two small rock chips
- Rear bumper has minor cosmetic scratch (inherited from first owner)
- Front bumper has small rock chips near the bottom; this is due to the parking location (normally at a parking lot, but sometimes on gravel)
Photos will tentatively be on carsales : http://www.carsales.com.au/private/details/Honda-Civic-2006/SSE-AD-2294226/?Cr=0&sdmvc=1
Will be uploading new ones in due time.
I am negotiable on price but am in no hurry to sell.
Please contact me (Gel) at 0487 319 697 or [email protected].
Thanks for your interest!
@Mods, if you'd be so kind as to tell me if I'm violating any rules here, it'd be greatly appreciated.
Edited by yummybuns
Due to the previous two trades falling through (RWC issues, price negotiation failures), I'll be more explicit in my requirements.
I'll set a maximum of $2000 cash your way for trades, and less mods are preferred. Again, not a realistic expectation, given
this is a largely mod-based community, but I'll still put it out there to make things less complicated.
Thanks for your time and interest!
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
