Gta51 Posted August 29, 2013 Share Posted August 29, 2013 Hi guys In the process if changing bits n pieces on my car for more power, Im aiming for the 340-360 rwkw mark on e85. Would that be enough for me to get a 10 sec pass in a manual 33 gtst ? Im assuming the mph would be enough! Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/ Share on other sites More sharing options...
XRATED Posted August 29, 2013 Share Posted August 29, 2013 in a word 'nope'.... the road your headed is either $$ or heartache. next question is why? why do you wan't to run a 10? Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993747 Share on other sites More sharing options...
zebra Posted August 29, 2013 Share Posted August 29, 2013 the power will get you there. but will need work with the suspension to get you there consistantly Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993748 Share on other sites More sharing options...
MagicMikeZ32 Posted August 29, 2013 Share Posted August 29, 2013 Because he owes me a 10sec car Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993749 Share on other sites More sharing options...
GTSBoy Posted August 29, 2013 Share Posted August 29, 2013 Getting below 11 sec in an R33 is more about tyres and rear suspension equipment than it is about power. Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993755 Share on other sites More sharing options...
R31Nismoid Posted August 29, 2013 Share Posted August 29, 2013 With 360rwkw, sticky tyres... a 10.90-10.99 is certainly on the cards if you can drive. Usual stuff like a working diff, clutch, suspension, tyres all required. Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993761 Share on other sites More sharing options...
Kane_R32 Posted August 29, 2013 Share Posted August 29, 2013 Cheaper solution.. http://www.gumtree.com.au/s-ad/regents-park/cars-vans-utes/nissan-skyline-r33-gtst-built-engine-445kw-e85-10-2-sec-st-car/1019091146 Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993784 Share on other sites More sharing options...
Count Grantleyish Posted August 29, 2013 Share Posted August 29, 2013 Cheaper solution.. http://www.gumtree.com.au/s-ad/regents-park/cars-vans-utes/nissan-skyline-r33-gtst-built-engine-445kw-e85-10-2-sec-st-car/1019091146 If I recall the car in OP's avatar, it already have some goodies from previous owner. Turbo is ext gated GTX3076 from memory. What are you changing out of interest? Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993794 Share on other sites More sharing options...
Gta51 Posted August 29, 2013 Author Share Posted August 29, 2013 Thanks for the replies Only reason I want a 10 is its more of a long term benchmark I can work toward I guess, it's well setup up engine and suspension wise so only thing I need is some et streets. If I recall the car in OP's avatar, it already have some goodies from previous owner. Turbo is ext gated GTX3076 from memory. What are you changing out of interest? ^^ correct it's got alot of goodies on it when I bought it.Car has arp studs, new headgasket, Npc 10inch carbotic clutch, either 1000cc or 1200cc injectors soon and a new tuner! Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993887 Share on other sites More sharing options...
zebra Posted August 29, 2013 Share Posted August 29, 2013 Suspension set up for the strip? Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993901 Share on other sites More sharing options...
Ben C34 Posted August 29, 2013 Share Posted August 29, 2013 Suspension set up for the strip? True. huge difference between track and drag suspension setup. Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993927 Share on other sites More sharing options...
Gta51 Posted August 29, 2013 Author Share Posted August 29, 2013 Currently setup for the street but will be strip ready when the cars tuned etc Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993928 Share on other sites More sharing options...
jet_r31 Posted August 29, 2013 Share Posted August 29, 2013 leave suspension or put stock shit in..buy slicks and frontrunners..., don't fit drag radials, even though its trendy unless you wish to break a lot of shit. cheers darren Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6994052 Share on other sites More sharing options...
zebra Posted August 29, 2013 Share Posted August 29, 2013 Why would you break stuff with radials and not slicks? Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6994065 Share on other sites More sharing options...
jet_r31 Posted August 29, 2013 Share Posted August 29, 2013 slicks absorb f**kload more shock due to softer sidewalls, radials absorb f**kall=bang go driveshafts/unis/gearbox Autos will get away with it far easier as they don';t "hit" the tyre as hard you can also pedal a car on slicks easier , radials when they let go are heaps harder to recatch/re-grap slicks as you start backing off you can feel them regrap People here are slow to catch on as radials are trendy to have, but they are a expensive way to go drag racing..and slower.. cheers darren Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6994107 Share on other sites More sharing options...
zebra Posted August 29, 2013 Share Posted August 29, 2013 Fair enough. But good luck finding front runners that will fit over the front brakes Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6994109 Share on other sites More sharing options...
LTHLRB Posted August 29, 2013 Share Posted August 29, 2013 Standard space saver maybe? Fair enough.But good luck finding front runners that will fit over the front brakes Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6994126 Share on other sites More sharing options...
zebra Posted August 29, 2013 Share Posted August 29, 2013 Last I heard they (ANDRA) banned that Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6994130 Share on other sites More sharing options...
jet_r31 Posted August 29, 2013 Share Posted August 29, 2013 (edited) theres heaps..my 15x4 convo pros with the bigger offset fitted over my r33 caliper and rotors..let alone all the 17 inch front runners they make these days that easily fit over them yeh space savers fit, i used them with m/t front runners aswell..but aren't they banned now ford stud pattern makes it piss easy cheers darren Edited August 29, 2013 by jet_r31 Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6994131 Share on other sites More sharing options...
zebra Posted August 29, 2013 Share Posted August 29, 2013 Didn't know they started making big dia front runners, good to know. Link to comment https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6994140 Share on other sites More sharing options...
