If I recall the car in OP's avatar, it already have some goodies from previous owner. Turbo is ext gated GTX3076 from memory.
What are you changing out of interest?
https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993794
Thanks for the replies
Only reason I want a 10 is its more of a long term benchmark I can work toward I guess, it's well setup up engine and suspension wise so only thing I need is some et streets.
^^ correct it's got alot of goodies on it when I bought it.
Car has arp studs, new headgasket, Npc 10inch carbotic clutch, either 1000cc or 1200cc injectors soon and a new tuner!
https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6993887
slicks absorb f**kload more shock due to softer sidewalls, radials absorb f**kall=bang go driveshafts/unis/gearbox
Autos will get away with it far easier as they don';t "hit" the tyre as hard
you can also pedal a car on slicks easier , radials when they let go are heaps harder to recatch/re-grap
slicks as you start backing off you can feel them regrap
People here are slow to catch on as radials are trendy to have, but they are a expensive way to go drag racing..and slower..
cheers
darren
https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6994107
theres heaps..my 15x4 convo pros with the bigger offset fitted over my r33 caliper and rotors..let alone
all the 17 inch front runners they make these days that easily fit over them
yeh space savers fit, i used them with m/t front runners aswell..but aren't they banned now
ford stud pattern makes it piss easy
cheers
darren
Edited by jet_r31
https://www.sau.com.au/forums/topic/431018-10-second-gtst/#findComment-6994131
