On the air intake on my R34 Neo there is a large plastic box attached to the throttle body and then to the filter housing outlet pipe.
Am presuming its an air baffle or dampener of some kind. What are the consequences of its removal? Just wanted to tidy up that area cause it looks cluttered and poxy. There is also a small one hanging below the pipe from the air box too. Thought or suggestions please?
Neil
https://www.sau.com.au/forums/topic/431021-air-intake/
Interesting. Haven't seen that before. Possibly a dampener as you said, most likely for noise reduction.
In any case, when my car was NA it didn't have that. So I'd say no consequences in terms of how the car runs.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-6994313
Thanks fellas. Was thinking same. @ Martin yours could have already been removed before you got the car possibly. @ Andrew yep can see the honeycomb moulding on the outside of the box. Have some assorted silicone bends laying around the shed so will remove and see what happens.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-6995147
Yes, no doubt. So I'd say you will be fine removing it :thumbsup:
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-6996345
the smaller box, hanging lower towards the airbox is a Helmholtz resonator, leave that on otherwise the intake is going to hum a very annoying note, it sounds shit without it.
you can remove the larger box, replace with a 3 inch 90 degree silicon joiner.
you'll need a bit of 3inch tube to sit inside the remaining plastic intake as a solid base to clamp onto (like a solid joiner between the silicon 90degree and the plastic intake)
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7006960
http://www.brighthubengineering.com/machine-design/84316-how-intake-resonators-improve-volumetric-efficiency/
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7007571
#@iseekool
thanks - the link is a good read, i'll be reinstalling the larger box tomorrow to see if it does increase the torque slightly (or my help with fuel economy, which is fkucing shirthouse for an NA) as i too ripped that large box out to clean up the engine bay.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7008249
  • 2 months later...
when i got my r34 I replaced my big box with a 90 degree pipe as it has a crack in it and was leaking, the smaller box had a crack in it aswell so I closed that off. Although my car got slightly more responsive and slightly better on fuel. I also had to replace the radiator and couldnt fit the 'cold air snorkel' as it didnt fit in between the radiator and the bonnet. So with all of that combined it sounds like a vaccum cleaner at idle and sounds like ITB's at 4-5krpm WOT.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7118353
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
