On the air intake on my R34 Neo there is a large plastic box attached to the throttle body and then to the filter housing outlet pipe.
Am presuming its an air baffle or dampener of some kind. What are the consequences of its removal? Just wanted to tidy up that area cause it looks cluttered and poxy. There is also a small one hanging below the pipe from the air box too. Thought or suggestions please?
Neil
https://www.sau.com.au/forums/topic/431021-air-intake/
Interesting. Haven't seen that before. Possibly a dampener as you said, most likely for noise reduction.
In any case, when my car was NA it didn't have that. So I'd say no consequences in terms of how the car runs.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-6994313
Thanks fellas. Was thinking same. @ Martin yours could have already been removed before you got the car possibly. @ Andrew yep can see the honeycomb moulding on the outside of the box. Have some assorted silicone bends laying around the shed so will remove and see what happens.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-6995147
Yes, no doubt. So I'd say you will be fine removing it :thumbsup:
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-6996345
the smaller box, hanging lower towards the airbox is a Helmholtz resonator, leave that on otherwise the intake is going to hum a very annoying note, it sounds shit without it.
you can remove the larger box, replace with a 3 inch 90 degree silicon joiner.
you'll need a bit of 3inch tube to sit inside the remaining plastic intake as a solid base to clamp onto (like a solid joiner between the silicon 90degree and the plastic intake)
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7006960
http://www.brighthubengineering.com/machine-design/84316-how-intake-resonators-improve-volumetric-efficiency/
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7007571
#@iseekool
thanks - the link is a good read, i'll be reinstalling the larger box tomorrow to see if it does increase the torque slightly (or my help with fuel economy, which is fkucing shirthouse for an NA) as i too ripped that large box out to clean up the engine bay.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7008249
  • 2 months later...
when i got my r34 I replaced my big box with a 90 degree pipe as it has a crack in it and was leaking, the smaller box had a crack in it aswell so I closed that off. Although my car got slightly more responsive and slightly better on fuel. I also had to replace the radiator and couldnt fit the 'cold air snorkel' as it didnt fit in between the radiator and the bonnet. So with all of that combined it sounds like a vaccum cleaner at idle and sounds like ITB's at 4-5krpm WOT.
https://www.sau.com.au/forums/topic/431021-air-intake/#findComment-7118353
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
