Hi all,
I am looking to get opinions on whether the Meguires lens restoration kit is any good or not? I have faded headlights, and i think it is all external and this kit seems like a good place to start.
Is this any good, or are there other products you would recommend?
Finally, is there anything else I need, i saw something about UV protector or some such?
Cheers
https://www.sau.com.au/forums/topic/431036-headlight-restore-kit/
Hi Lemonnuff31, I had this same issue. My headlights were getting opaque with a slight yellow tinge. I didn't purchase a kit and opted for three of the lightest grit sandpapers to use in conjunction with plastX and a polish buff drill bit....think i saved 20 bucks or so doing it this way. It did the job nicely and i was happy with the result. I think with the plastics used on headlights these days the coloration and smokiness is bound to happen with exposure to UV and the elements. I don't think its a one off thing to restore headlights but a little job that needs doing maybe once every few years to keep them looking immaculate and clear. There is science behind different plastics and how they react with varying chemicals and when i cleaned mine i didn't get to finicky and just went with the most tried and tested approach. When i do mine again ill be using the Meguires Kit you mentioned.... It comes with the plasiX included in the kit.
bought the decent kit from autobarn... looked immac for about 3 months then the UV sealant started to look patchy like it was flaking off and the yellow started to return... think next time I do it im just going to use a polishing pad drill bit and buff the f**k out of them as a plastic s13 grill that was yellow turned out amazing with the buff pad
I have tried one of the kits (RainX kit). And if I had to them again, I would just be buying several fine grades of sandpaper and looking for the sealant on it's own.
I found the polish that came with the kit was next to useless. After using the sanding pads and perservering with the supplied polish, I ended up using my rotary buffer with a foam pad and a fine cut paint cleaner which did an awesome job of cleaning up the headlights after sanding. Made them look brand new. I then just applied the sealant the came with the kit. PlastX with a rotary buffer would probably work well too.
That was about 6 months ago, I live in North Queensland and my car is parked in the sun all day, and it still looks great!
Meguires do make the UV sealant on its own. Only problem is they do not sell it in Aus....YET!
Invision do not make the sealant by itself. I did ring them and they said they plan to do a bigger bottle in the future amd sell the products individualy in the future aswell.
Will the invision pack you need to be sparing with the sealant. V35 headlights are exactly small.
Lol the Meg's stuff is useless shit! Last about 3 months, and becomes worse than before a lot quicker. Their sealant is .... Okay(loosely used) but doesn't last very long.
I used the glassylite kit off eBay( $35) and it lasts about 10months to a year. Pics?
Check out this shit
Don't have any before pics as I wasn't expecting THAT good of results. But it worked wonders.
  • Like 1
  • 3 weeks later...
guys the resto kits all work great, toothpaste will work great....we need to find a good sealant which stops the degrading process and group buy.
must admit the kit i got from sprints, i think maguires, has still held up very well for months.
    • Got my R34 gearbox around 4-5 weeks ago. Came into some extra $$ recently and after I cleaned the mess off the notes, I thought, might as well buy that R34 box I've been pondering.  In that time I've pulled the engine out, replaced rod and mains bearings, done a few other engine things that are much easier with the engina out eg PRP oil pump upgrade, replacing wastegate coolant lines, installing Turbosmartass turbo oil pressure reg, made some mounting brackets for some of my mods that are "hard to reach", converted the R34 box to R33, put the engine and new gearbox back in the car. Plus cleaning ...Oh my god so much cleaning when doing such a project. Yep I'm a busy bee, buzz buzz. As part of the gearbox project, researched posts and found this thread (In which i nailed it for the OP), hence the post here # logical thinking.. Not all about you old boy, SOrrryyy. Dare I ask,  how's yours going ,> Or you got it done yet, and if so why didn't you post any of the tips I posted to help other members? ???
    • Seems to be the case mate , still an OK price for a grey import.
    • I’m interested in the carbon diffuser fins and Toshiba MFD screen replacement if they’re still available.
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 🙂
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
