Hey all, just bought a 33 gts-t and plan to fit a FMIC this weekend.
To make this fit have had to install a POD filter and just a little concerned with the gap between the AFM and the adaptor ($12 from Supercheap)
It's a genuine K&N filter, there was a rubber gasket that came with the adaptor, on the sides where bolts are closest it seems to seal properly but I am very concerned with the long sides as there is a visible gap between adaptor and the paper seal on the AFM - don't want any unfiltered crap sneaking in.
I'll post a pic as soon as I am using a computer, any help would be much appreciated. For now put stock airbox back on until I can be confident the filter is sealed properly.
https://www.sau.com.au/forums/topic/431038-r33-pod-filter-fitment-question/
just remove it and hammer/sand/grind flat whatever isn't flat.
otherwise have you tried tightening the bolts more? obviously you don't want to crackt he plastic of the AFM but there may be more tension you can put on it...
All tightening the bolts more does is pinch the rubber so we have a big lip of rubber hanging out.
There's a paper gasket on the AFM that was there from stock, I'm going to try straighten out that plastic adaptor and affix the rubber gasket to it then report back.
Seems crappy Supercheap plastic adapters are not all that great
No thats not what i meant.
Ill exagerate for this scenario..... Say you do the right bolt up to 1000Nm and then you do the left bolt up finger tight. The AFM is going to pull crooked (told you I would exagerate)
I didnt mean just tighten the other bolt up more. I was just making sure that they were pulled in evenly
