Hey guys, new member here, long long long time lurker (reading but not posting).
We're in the midst of an RB25DET NEO build for an S14 (240SX) and I am running into an issue...
The engine we have is from an R34 GT-T and when we pulled the stock damper off, it kinda fell apart. So we need to buy a new one, but I'm trying to understand why RB26 spec units are half the price of an RB25 spec unit, and also to understand which version I really need for a NEO engine.
One piece of information I have found indicates it's the crank snout difference between the RB25 and 26, but I've also read that the NEO has the same specs as the 26 in that respect...
Does anyone here have any other information on what is different and why we should pay double the cost for a 25-spec unit?
TY!
supply on demand... more demand for a 25 balancer i guess?
also you will find the power steering belt is different on the 25 to the 26.
Yes I understand the economic reasons for price differences... :P
I'm asking if there is a mechanical or functional difference between parts made for the 25 vs the 26.
IE, why couldn't I use a 26 instead of a 25? :)
It's a good question, as for the sake of a new belt it would still save money running the cheaper balancer. Not sure what the differences are myself, but I have a neo balancer on my rb30 crank.
Really depends if it under-drives or over-drives. I'm not sure if you can use the power steering pump off a GTR and it will work fine. I got my Ross Balancer for a touch over $600 which wasnt to bad
Thanks for the replies, all.
I should say, we are planning on putting an N1 RB26 crank into the engine, so I know that the 26 dampers will mount to the crank..
I was mostly worried about belt positioning, ie, the distance between the block and the accessory drive pulleys, being different.
If the only issue is belt length, well, that's not really an issue, we can figure out what length of belt is needed. :)
Anyone have any input on using a 26 damper on a 25, aside from belt length concerns?
TY!
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
