Hi guys
I am in the market for a top mount steam pipe manifold with 44mm external pipe. I dont want a cheap <$500 one with terrible design and collectors like scrambled eggs. I am aware of 6 boost etc that offer good manifolds for >$1500,but surely there is a few people making manifolds for around the $900-1000 mark.
I'm looking at Go Pipes on facebook at the moment but would like more options. The main thing I want is neat even collector point.
https://www.sau.com.au/forums/topic/431047-turbo-manifold-options/
Last I checked 6-boost and ETM were both 1200-1300.
I have 2 mates who jumped on the merge collecor band wagon. Both which do them for the 800-900 dollar mark.
But my advice is go with 6 boost or ETM
They're are much neater and better fitting than the cheaper ones
your willing to spend $1000 on a manifold but not $200-$300 more on a 6boost?
I dont understand, they are amazing manifolds, proven over and over to increase response and power
Just remember $200 wont seem like much later on when/if you regret buying a different manifold
Post up some pics of the manifold when you get it.
EDIT: just saw your post...... just go with the 6boost!!! $1300 is cheap.... Manifolds like mine go for $2500USD in the states. And from what i gather 6boost manifolds are like $2k!
I probably woulda dished out the extra $200-$300 for the 6boost but I haven't seen the Gopipes manifolds before.
Do they build them out of cast SS weld-el's? Fully backpurged? ported? what diameter runners?
My buddy just finished fabbing up my manifold this week. Twin Scroll T4, 2in diameter Runners, fully backpurged and ported. He build the collector himself instead of getting those dumb 6-1 premade ones. just need to place the gate this weekend and take it for ceramic coating.
1236410_10202131428910970_1040248122_n.j
1011654_10202131430991022_407224748_n.jp
1233632_10202130711013023_447571748_n.jp
Edited by R32N00B
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
