My mistake gents
Not 2in ID, yes the od is actually 1.9in hence the confusion
Weld els measure differently than regular pipe
Medium runner manifolds (typical manifolds you see like 6boost/full race etc) are 1 1/4" weld els but have an inside diameter of 1.44in (od 1.66in)
Mine was built with "large runners" 1 1/2" weld els
Which have an inside diameter of 1.66in (od 1.9in)
Sorry for the confusion there. But this thing is just massive next to the full race we have sitting around its so much tighter together with the larger runners.
It's also not thinwall like someone said
This is stainless steel 304 schedule 10 pipe
It's like the 6boost but it's stainless not mild steel and larger runners
Edited by R32N00B
what i meant to say is pipe measures differently than tubing.... tubing is measured OD where pipe is measured ID.....
1.25" pipe has a 1.25" ID (on schedule 80 pipe) the OD stays 1.66" so schedule 40 pipe will have a larger ID and schedule 10 even larger. Thats why my 1.5" pipe has an ID of 1.66".... it only has an ID od 1.5" on schedule 80 pipe....
hope this makes sense
Makes sense. It was clear that it is huge, as it takes up all the room between the engine and, well, everything else on that side of the bay!
I just said it looked like thinwall because the welds are more like the welds you see on tube. But given that you have used Sch10 pipe, which has only a 2.77mm wall thickness, that explains the welds. Not as thin as tube, but pretty thin for pipe, hence the welds end up looking wide and flat.
ya sch 10 is .109" (sorry im going imperial on you lol its what im used to here in the states)
schedule 10 pipe is PLENTY thick for manifold. as long as its built and welded/backpurged correctly it's the optimum thickness. Any thicker is a waste and will weigh quite a bit more, and also will have smaller diameter ID. At least this is my fabricators point of view. He hasnt had one crack yet and they're out getting all out hammered on a daily basis.
Edited by R32N00B
also as a note on the welds my guy likes to taper the "butts" of the pipe all the way to the ID. Typically they come tapered halfway in but he likes to taper it the entire way, that coupled with full backpurging allows for deep/full penetration.
How can it be off topic, people need to realise the stock manifold isn't the restriction it's made out to be. I must admit I was surprised with this result.
I did the recent fab work on it, the car is still restricted by a hollow 3 inch cat in the 3.5 inch exhaust, return flow cooler, and the Z32 afm still holding back the 4 inch intake. There would be much more in it if the gearbox could take it... Not too laggy either imo.
  • Like 1
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
