No will, the asphalt for the track will be millions of dollars by it self
Then there's buildings, services, driveways, leveling the land, amenities, permits, insurances and that's would only be the beginning of the expenses
ive been in contact with one of the Founders ( via her Motorcycle facebook page ) she said this..
" We are just working with the council on some minor ecological assessments that arose in the DA process.
The council amalgamation has been a spanner in the works and had delayed a number of actions as well. Everything is still progressing well, just taking longer than we hoped because of these two factors. "
It's still all good and going ahead, just typical council crap. The merging of 2 council areas hasn't helped the situation
niZmo man pretty much summed it up unfortunately...
" The money is not an issue. We continue to work closely with the council on ironing out the last of the DA hurdles, but I cant predict their timeframes "
I only live 10 minutes from where they want to build this, safe to say I cannot wait...
There is some locals that live along the road it will be near and they are trying their hardest to get it shut down but it's like 100 vs everyone in NSW. So not an issue
You really believe that? Sydney international airport has a curfew because a people's complaints, so stopping a race track because of complaints wont be to unrealistic
This.
However a plane impacts on are larger area, I'd like to think you could install dB meters on the perimeter and abide by whatever standard and be able to fight complaints (subjective) with factual data.
by people complaining i litually mean they are whinging to each other on facebook and thats about it.. no petitions no signs no nothing. They arnt exactly trying very hard. more like the ramblings of a small group of grumpy small town people
  • Like 2
I know i said they are trying their hardest... but this is them trying their hardest. They are a very lazy small group of people who by the sounds of it have nothing else to complain about.
​When ever someone says something against their opinion they come back with " why don't you put it in your backyard then" and so on.... they are posting on casar parks facebook page and complaining on the local facebook groups.
​BUT no petition, no " casar park isn't welcome" signs or anything like that and pretty much every single other person wants it to be built because of the income it will bring to the area, business's will grow, property values will go up etc etc
Goulburns new motocross track got canned because it might upset some chickens on a chicken farm. That's right, chickens not people.
Dont think that just because its 10 people it wont get shit canned
  • Like 1
Well the land they are putting it on is owned by 1 man who is also Aboriginal. He has given his written permission etc
Do you have a copy of his proposed contract? Why does him being aboriginal make a difference? Genuinely curious
Could be a case like magenta shores, where the land is leased.
Only really makes a difference if the media/protesters can use it to their advantage, spin a tale of stolen land as they do. If he's on board than good on him! And yeah it makes no difference.
It was one of those " Claimed Aboriginal lands" and he happened to legally buy it after he claimed it.
Just made it easier to use the land I guess.
Basically it doesn't make a difference. There's a 20year lease with him and he wrote a massive letter supporting the project and sent it in to the council. Or something like that
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
