Yes I have the 6 pole version but am looking at something that will allow me to use a remote switch on the outside and inside as I don't wish to use the pull cord.
If you look at the few options on here
http://www.demon-tweeks.co.uk/motorsport/battery-isolators-master-switches
The Brise and ETA 921 could both be used but are expensive, I was looking at something like I mentioned above if it was a viable alternative.
I've done a few rear mounted battery race cars with solenoids. If it shuts the engine off than its still cams compliant. A lot of heavy earth moving equipment ( mainly komatsu) uses electric isolation switches.
You simply wire a switch in the dash and a switch externally in series to the solenoid so that if either one is switched off it turns the solenoid off.
If wired correctly the only down side is that there is a small amount of current draw while the isolation switch is "on" , so it can't be left on for days at a time. But if it's a race car than it won't matter.
I've been going to do a r33 ISo switch write up I think I should do an electric ISo one as well soon.
That diagram above is pretty much it. Pretty simple
You can buy a double pole solenoid that will open circuit another circuit like the Motorsport version ISo switches. Like alt field or ignition.
The way I like to do it is run the alt battery feed to the live side of the ISo switch. But if your rear mounting a battery this kind of defeats the purpose.
If you use no other means to shut the engine down than the battery feed to the alt needs to go to the battery side of the isolation switch. There is a diagram in the Motorsport section on how it needs to be done.
If you use ignition or alt field isolation than the alternator is no concern
Cost, weight, simplicity, because race car.
Revolution and other Motorsport shops sell cams approved isolation switches as a manual switch. If they sold the solenoid as a kit everyone would fit them.
Plus the external toggle switches fail over Tim where as a pull cord will not.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
