so youre saying that everyone whith launchcontrol is a ricer and whants to get noticed ? first of all these limiters are safer for a engine you can install les revss and no fuell cutt duo to cutting the spark signal thats why unburnt fuel detonates in the elbow, but as i said it would be fine if you dont turn gain up to high which some people do because they like they bang bang indeed and yes high gain and overuse can damage but i said that my plans wherent use a high gain, so please stop bashing the limiter now and my choiche to buy one my car its my money Mkay?
My brain hurts due to lack of oxygen. Please say again in some sort of English.
End of the day, you don't need it. Post the specs of your car.
Cutting fuel is a safer fuel cut than cutting the ignition (which is why every car manufacturer does it). Cutting the fuel simply means the spark plug fires but it does nothing. Creates no heat or stress on anything. Cutting the ignition is bad for the turbo and exhaust due to the excess heat and pressure.
The only real use for this type of ignition cut is if you want to build boost while banging on the limiter in neutral, such as in a drag car.
As for whether it's genuine or not, does it really matter? From what I've read, the fakes still seem to work fine. As long as the price was reasonable then move on.
Cutting fuel is a safer fuel cut than cutting the ignition (which is why every car manufacturer does it). Cutting the fuel simply means the spark plug fires but it does nothing. Creates no heat or stress on anything. Cutting the ignition is bad for the turbo and exhaust due to the excess heat and pressure. The only real use for this type of ignition cut is if you want to build boost while banging on the limiter in neutral, such as in a drag car. As for whether it's genuine or not, does it really matter? From what I've read, the fakes still seem to work fine. As long as the price was reasonable then move on.
nicely said.
I thought cutting spark was safer as it prevented leaning out and melting pistons?
I have no experience with them but it makes sense. Could overspin the turbo if the fuel ignites in the turbo though.
If there's no fuel there'll be no ignition (as in no bang), so no risk or pinging or higher cylinder temps
Spot on. No fuel = no bang = no heat. And even if you had the tiniest amount of residual fuel vapor in there, it would actually be so lean that that it wouldn't actually cause much heat, if it was even enough to ignite in the first place. You get to a point where leaning out doesn't get hotter, and temps start to drop. Think about it, if you have a big fire it heats up a big area, but lighting a match in the same area won't do squat.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
    • There are guys on Facebook under, Infiniti Owners Australia   https://www.facebook.com/share/g/1Z3RbPqx4k/?mibextid=wwXIfr What Whp are you after and I can help, and join this Q group in the states. https://www.facebook.com/share/g/19A59cN3JR/?mibextid=wwXIfr
    • Does any of you guys have instagram pages for your builds? Keen to see some Aussie builds. I still can't figure out how to post photos in here.
