  • Replies 42
yeah mate still got it, but it's not for sale as its being used in my current set up.
Just selling the parts that I no longer require as it has been upgraded to full cage, 26/30 setup and the rest.
Just cleaning the shed to keep the missus happy!
All still here! disc brakes and calipers are the cheapest I've seen on this forum. So for great deals have a browse and make us an offer.
Once again LOW BALLERS will get NO REPLY.
Cheers HULI
Can i grab the front upper camber arms for gtst?
foolishly threw mine out when i swapped to ball joint arms but want to revert back to a softer ride
PM me details, postage to 2642
Edited by jazzy_
lots of people asking questions but not really any takers.
If you want a faster reply to any questions, just sms or call on 0400262578.
Cheers HULI
need this gone by the new year!
make an offer on already cheap items!!
FOR QUICK REPLY CONTACT ME ON 0400262578.
Cheers HULI
Edited by huli
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
