Massive Aftermarket Skyline parts clearout - parts to suit 32, 33 and 34. Some big ticket items going for a song!
Contact: PM or phone 0413 863 207
Payment: Cash or postal money order ONLY. Strictly no paypal or bank transfer - don't ask!
Condition: All parts as described or money happily refunded.
Will post smaller items at buyer's expense
Genuine RIPS RB25 intake plenum with Nissan throttle body. $750
NPC big mouth clutch suit RB25. 90% in mint condition with pressure plate and flywheel $450
Genuine Nismo strut brace with brake stopper. Polished with stainless nuts etc. $200
Surge tank set up with pumps and lines. 1.5 litre tank, Bosch 580 lift and Bosch 044 external with lines filters and lift pump mounted in 33 cradle. $355
Siemens 750cc injectors and Sard fuel rail. $600
HKS fuel rail and mounting kit. Brand new. $400
ID 1000cc pencil injectors and loom. $600
Siemens 550cc injectors. $450
Sard fuel pressure reg. With fuel pressure gauge $150
Stainless t3 manifold brace welded. In excellent condition $145
Tial blow off valve as new with vband $75
Power spirit cam gears. Unmarked as new. $150
R33 s1 split fire coilpacks x2 – loom not included. $300. Loom extra $75
PWR large alloy radiator suit R33 some bent fins but in excellent working condition, less than half new price– $400
R33 Aftermarket alloy radiator. $150
Just jap R33 GTR Intercooler 100mm. $150 SOLD pending payment
Auto meter oil gauge. $75
Saas boost gauge. $50
Auto meter boost gauges x2. $75 each
Turbo timers, various. $50each
Catch cans x 2. $40 each
Custom stainless Garrett 35R heat shield with extended drop side to protect R33 factory wiring. $150
RB26 cover set – rocker covers, timing case cover and valley cover. Rocker covers with -12 weld-on fittings. Stripped ready for paint. $300
  • 2 years later...
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
