^^^^^ this is correct providing you don't have a runner spacer.
Just an FYI.....you will find that Dales Brace bar will probably make a bigger and more noticeable improvement.
i have upper and dales lower. Top might aswell be for decoration as it does SFA compared to the lower.
Also easy as to put in and dale....bit odd but good bloke hahah :-P
https://www.sau.com.au/forums/topic/431139-m35-strut-brace/#findComment-6998749
Pretty sure bigkevracer got the ox motorsport bracing off streeter for the m35
Sorry haven't got on here much lately. I've got Dale's front brace, the OX rear that Jetwreck organised in the group buy, and a Freeway Dolphin strut brace that Streeter organised.
These days I think the strut brace serves more use as a place to cable tie hoses to, but I've left it in. Looks purdy, and makes some difference, but with Dale's brace and all the bushes replaced, front end is pretty direct without it.
https://www.sau.com.au/forums/topic/431139-m35-strut-brace/#findComment-7003132
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
