  • 3 weeks later...
well ive been busy at work and havnt had a chance to update for a while but good and bad news.... good news turbos back on with dumps and front pipes all good to go... bad news is that the ARC Airbox didn't fit with my Greddy intake kit :(
  • 1 month later...
well the surprise was a T51R!
it was almost ready to tune but decided to buy the HKS T51R KAI BB as ive always liked the sound and thought its time to put a single and start having some fun!
So tuner had to take off turbos again and put T51R on, its almost done, taking a little bit longer than I expected but needed to fabricate dump pipe, plumb the screamer into the dump pipe, once finished should be wiring in haltech and ready for a tune.
expecting it be finished real soon.
in other news I have a 4000km old twin turbo setup and some parts as you can see that only ever got bolted on and never used all up for sale :D
more to follow in the next few days
The Car then made its way onto the DYNO where a leak in the inlet manifold gasket was found, so it got replaced with a NITTO Gasket and back on it went.
first was a tune on 98 @ 16psi and made 317kw we left that as the 98 tune as the car was going to be set up with FLEX TUNE and mostly run on E85.
the car then pushed 380kw @ 21.5psi on E85.
It's a little bit laggy compared to the -5s but you can feel the car build the power and the power delivery is amazing! Compared the 2 the t51 comes on boost later but it still has a feelin of torque in the midrange but it's a lot more dinner to drive and it feels a lot better to drive aswell the power delivery between gears are faster than the -5's overall happy with the decision to change. The twin turbo setup felt lazy and sluggish where the big single feels free and open if that makes sense
Cool. always interesting to hear how the car feels vs the dyno considering power and tourque are lower down low...good feedback! Must come on pretty strong!
Good point about performence between gears. I guess the power/torque differential down low isn't an issue between gears because you're in the higher range on shifts so you're net/net higher on both power and torque while you're hammering vs -5s.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
