As add title says, im looking to return my car back to stock, all parts are AS NEW CONDITION
Looking to sell most of these parts with the condition that im given the stock part, so price is determined/negotiated with that in mind, my parts are mint so id need stock parts in mint condition too.
Power FC with Hand Controller ( current E85 tune) - $1000
GT3076 ( HKS3037)with 0.82 Twin scroll rear with gate pipe on housing(ceramic coated)- $1100
Tial 44mm gate with springs( these are $620new at MTQ)- $350
6boost low mount manifold Twin Scroll( ceramic coated) $1000
Z32 airflow and plug( cost $350)- $200
3 1/2inch dump stainless steel with gate pipe return(cost $800 to make) - $400
1000cc Xspurts in top feed rail ( was on r33)- $600
Turbo smart reg $200
4inch intake pipe, connects to z32, has whole for bov return-$100
Rear aftermarket bumper
also have a set of Tein coilover which im open to offers, these are Jap spec fully adjustable, firm and in VGC.
Located in south Brisbane 0466 257 118
Open to sensible offers.
Got a pic of metal intake?
Pics to0497075260
heres a pic of the pipe and other bits for sale
the big black pipe going into the turbo with bov and afm attached
post-70965-0-23565100-1378107141_thumb.jpgpost-70965-0-36530200-1378107289_thumb.jpgpost-70965-0-05902200-1378107296_thumb.jpg
Dump pipe was made by Dan at Elite automotive for the GTX in stock position, its since been shortened about 6inch to suit the lowmount and gate, its pretty easy to make it fit a stock position again, just lengthen it again, cost me $850 and is quality stainless steel..
Edited by AngryRB
Power FC and z32 AFM SOLD PENDING PAYMENT
rear housing that is on turbopost-70965-0-84556800-1378156943_thumb.jpgpost-70965-0-28983900-1378157067_thumb.jpgpost-70965-0-83713400-1378157172_thumb.jpg
Has perfect boost control and the mouth has been ported out for more flow to match the 6boost manifold flange
Edited by AngryRB
Interested in the turbo mate, can you post up some pictures of where the gate pipe is on the turbine housing? Cheers
Currently someone considering buying the turbo,Gate,manifold and dump as a package, will let you know if they don't buy it today..
i can testify that having the gate in that position is perfect for boost control. had 6boost do the same on my gt3076r housing back in the day and it was excellent
Thanks mate,
Tein coilovers( these are firm, jap spec) $700 or $600 plus your stock suspension, Postage is extra
Rota Grids - 18*9.5, offset 30 comes with tyres, rear 2 have plenty of meat but cheapish, front tyres are Kumho21 $800
Rear bumper- needs some paint and small repair $180
bumper picpost-70965-0-77986000-1378177059_thumb.jpgpost-70965-0-97429100-1378177147_thumb.jpg
rear
Edited by AngryRB
will also package deal the Injectors,Rail,FPR,Fuel pressure gauge and the speedflow fittings on the rail
for $700, perfect for E85 upgrade.. made 320kw at 70%duty
Turbo,Dump,Manifold,lines,Gate,intake pipe- SOLD PENDING PAYMENT
also have a R33 GTR dash OEM - $350+ your stock cluster or $400 withoutpost-70965-0-03170800-1378338535_thumb.jpgpost-70965-0-54681700-1378338563_thumb.jpg
Tomei Poncams 256 8.5lift with less than 10 000k's on them- $550 + your stock cams ( prefer local )
Edited by AngryRB
heres some extra pics, I will peal off parts as there bought... these teins are firm, bought from Jap wrecker few years ago, they are not worn out, 16adjustments which when turnt definitely make it firmer, if you have a drift car these are perfect, ive used them on the street for 3years, there not too bad.. make the car handle like its on rails..
fuel system bits
wheels are in great condition, still have receipt for them, also will fit a falcon
check out the stance.. lol
Edited by AngryRB
Thanks mate,
front[attachment=435295:20130903_124143 (640x480).jpg
rear
What size tyre on rear? Any guard work required to fit on gtst?
on the rear is 245/40 , id say you could squeeze a 265/35 on the rear though
I have my guards rolled, the fronts could use a 5mm spacer as there a slight rub if you get a hard full lock on but hasn't been a drama for me... These wheels are big but no heavier than a stock wheel from what I can tell.
  • Like 1
hay mate can u send me some more pics on the fuel set up and some more info on it
These parts are like brand new, are 12months old and were purchased to convert to E85 and worked very well, nothing wrong with any of it, these injectors are very high quality and theres zero issues with this setup..
This is where I bought them and what they look like http://www.injectorsonline.com/indivprod.php?cid=106&scid=40
I have modified this rail so it can bolt under a R33 in place of the stock rail so this is rare, the manifold got a brief shaving so the rail fits in.. There is a write up in the DIY section with an example of this but using 750cc Xspurts here http://www.skylinesaustralia.com/forums/topic/403711-top-feed-rail-in-r33-with-stock-plenumyes-it-can-be-done/?hl=+750cc++xspurts
Edited by AngryRB
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
