Pretty sure iv seen this in Kent street Hamilton area
Yeah I visit that area sometimes so id say it was me,
Did you have to take the inner guard lining out to fit your grids btw or roll the guards?
I had the guards rolled when they were fitted and the guy zip tied the lining to the guards, bit fiddley but can be done.
are they direct plug in to loom or do u have to get the plug for the injectors and is there any chance of some better pic of it all and is the fuel reg still attach to fuel rail. i keen on it all just what more info
I will Remove the parts tomorrow and give you a photo of the exact setup and parts, The plugs are part of the sale as I am looking for the stock rail etc off whoever buys this...
cant believe this hasn't been bought yet... the injectors alone are worth $600 and about the best injector on the market.. :/
Edited by AngryRB
PRICE REDUCTION
Fuel setup $650 or $600 +exchange for a stock rail+injectors
Rear Bumper $100
Tein coilovers HA $600 or $500 + exchange for stock suspension
Rota Grids - $700
2 GTR BOV's $70
GTR Cluster $350 or $300 + a stock cluster
Tomei Poncams- $500 + stock cams
P.S- DO NOT ask me to bring the parts to you, do I look like a courier service?? giving me the shits..
Edited by AngryRB
Can I get more pics of coilovers?
There still on car, they are all green like the last pic, will post more pics soon, all in Perfect working condition
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
