hi guys,
i am after a small part for my v35 coupe i dont know if wreckers would even bother selling it lol so thought id try here if anyone has a wrecking v35 coupe or would know how i would fix the problem?
I was installing my sub and amp and then realised that the plastic bit to keep rear seats in place had snapped! so im after that piece to replace otherwise any other suggestions in fixing it?
Also after the passenger side sunvisor (dont think my chances are high at all) as i need one in the beige colour scheme 70th anniversary model)
Thanks,
I got my fuel float from Import Revolution in Melbourne, he was definitely the cheapest option, and very good to deal with. I would recommnd giving him a call, as he can probably assist with the other parts too.
http://irev.com.au/
  • Like 1
http://irev.com.au/
Recall what it cost you? i just need the plastic float, not the fuel level sendor
Yeah i needed the same, as i snapped mine off completely. I have the receipt around somewhere but i think it was around $60-80 which included being send from sydney to melb. Do you need the plastic float from the drivers side of the car, or the one from the passengers side?
Whatever you do, don't go to the dealers, they wanted about $300 for it!
The drives side, it fall off when i was taking the basket out.. $60 for a plastic float.. damm, i think ill just fill the car up and rock it side to side and hope it floats back up where i can get it !
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
