Mugabetown - Whoretownin' At It's Worst.
Panel gap and the batman... Pretty sure it's nick...
I'm B@man
Errrr excuse, but do you have a RWC for this vehicle?
I'm B@man
Well as a matter fact I dont mr officer............................why is that (officer asks)?
'BECAUSE ITS A FKN BAT-MOBILE"
...I'm B@man
so let me understand this correctly...........................if a mod / admin is an bad mood they take the banning stamp out and slap you in the face with it :blink:
Yai - to being banned for genuinely breaking the rules
No - to being banned just because you someone can ban you
You understood it just fine. People seemed to take it with much better humour. People are a bit self important and precious about the forum these days.
Since when did Ben Affleck join the forums?
No, Bad Tony
Indeed...I'm B@man
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
