Mugabetown - Whoretownin' At It's Worst.
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
    • That's the one I have in my R32. There isn't a bigger battery that will fit an R32.
    • Not sure what you mean haha. That one doesn't fit mine but when I get sick of my one I'll get a standard one. I just gotta find a way to make it fit cause some shit is in the way.
    • https://www.supercheapauto.com.au/p/century-century-ultra-hi-performance-4wd-battery-ns70x-mf/602477.html MF for Muthaf*kka
