Mugabetown - Whoretownin' At It's Worst.
I wouldn't worry too much Ants then, the other gaskets will.most likely arrive by then anyway. Thanks for the offer though. I've put off getting anew cat for over 6mths now another week shouldn't kill me. Kinda wondering wether theres gonna be a volume level differencd has currently farked stock one in it.
From my experience there is no difference in sound
I still don't understand how something with holes in it stops anyrhing
What do you mean?
The cat is there to heat up and catalyse un burned hydrocarbons,carbon monoxide and nitrogen oxides into more friendly substances
What do you mean?
Surprisingly that came out really.well and I understood all of that.
ok go! are a band, so i wouldnt suggest you get them to fabricate an external fuel system for you.
if they can fab anywhere near as good as they can use treadmills, then I'll use them!!!!
RandomHero / Pannel Gaps / TheB@man is no longer affiliated with the Skylines Australia website, Members may contact me via the usual methods but i have no further intentions of utilising this page and thus encouraging and supporting a site that is Administered by Egotistical people. Thanks for all the whoring fell's an gal's but I'm done here.
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
