Mugabetown - Whoretownin' At It's Worst.
I've been forever pondering lately what gets prioritised through workshops / tuners
seems like FIFO is not something you can rely on as turnaround indicator
I think FIFO is the goal, but in your instance it was something that required extra work they didn't account for so inorder to get more cars out faster yours sadly went on the back burner :(
Whatever order makes them the most money the fastest?
here are my thoughts
regular service work = consistent cash flow = priority no.1
sponsoring work = zero immediate cash flow but free advertising = potential future cash-flow = priority no.2 (my mind is still debating this)
project work = infrequent cash flow = priority low
all the above depends on size and demographics i.e. manpower of the workshop(s) but as a general rule of thumb I don't think I'm too far off the mark.
Also for non service work i.e. large repair jobs or builds - if a workshop tells you it will cost you this much $xxx - budget for $xxx * 2 as there will always be additional costs they fail to mention (unless you know someone who will do it at a discount or lower chargeable rate)
Or get Dan to build your engine...
I'd say sponsored work goes to the back unless it will have immediate impact on future business, e.g. a sponsored car shits a bearing right before major event. This is bad as visibility is important so it'd go up the queue, otherwise it'd be dead last IMO
would really depend on the type of sponsor being provided to really answer that question
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
