Mugabetown - Whoretownin' At It's Worst.
Alledgedly everything is still running but the USB port slows down and Sean cant get any proper reading from it.
Haltech was sent back to Sydney yesterday (hopefully will get it soon) to have a look at it.
go in there man honestly. i dont know they guy but you know they havent touched it and now they claim ecu is dead. Id hate to find out they are jacking you man!
Hatlech said to Sean when he called them that this ECU has an older firmware on there and is apparently a known issue.
I asked Sean if Hatlech would replace it with a new one - hes said he doesnt know.
bottom line, is that I still have no car, and now no ECU im totally devestated with it all.
Never really thought of that Damo. I suppose workshops could pull BS like that and would not be suprised.
thats so low BTW.....
Back in the late 80s when the band was only first starting off buntas clean cut style dazzeled female onlooker to the point where photosynthesis was so popular fans start submitting their crowd shots (as seen below)
But by the early 90s the folk lifestyle had taken its toll on poor mr bunts and the band started to fall apart due to alcohol and drugs
After two stints in rehab and a rumoured romance with Michael Jackson, the band went into hiding secretly writing there controversial new album "Give me the keyboard to your heart... And your car" two years later the album was released to mixed reviews selling only 300,000 copies
I am not convinced that is the correct use of photosynthesis.
I don't think think using radiant energy to turn carbon dioxide and water into carbohydrate is the cause of your being boring. Though according to Ants you are green so maybe you do photosynthesise
I was a bit dubious on this use as well but Video ref has called play on...7 tackles later.
Less than half mate. $29 inc Cart hire for 18 holes. Practically giving it away
Is that for 1 or 2 people?
doesn't it still have a serial port as well? could of upped the baud rate on that in a pinch if it does.
  • Like 1
Go in there with a glitter cannon, that would make most people other than myself move quickly....
Unless they are like me and in which case they will be waiting in excitement for a shitload of sparkles to explode everywhere :)
(I changed my mind we can be friends)
Yippeee
My guess is that it is an excuse to buy them some time
Just no, Sean did not manage his workload well coming into two major events but he would not send an ECU back to Haltech to buy himself time.
    • Neo IACVs have water plumbed into/out of them to provide the heat to close the AAC. I am also unsure about vanilla 25s, but maybe the extra plumbing on that is water.
    • Those injectors are 100% Nismo 555.
    • I found this in another thread, now I'm second guessing myself and thinking there was a vac line from near the throttle body to up to the IACV too.   https://saufiles.s3.ap-southeast-2.amazonaws.com/post-59171-1251456228_thumb.jpg
    • Hey Duncan,  What ports are on the plenum itself? The new part welded up for the AAC looks like it's a T Piece to go upto brake master, and the other side into the plenum to feed air in. Brake master vac line on R33 from memory has a one way valve inside of it I believe (middle of pipe). I'll check mine tonight when I get home, I think that pipe is still sitting on my R33. You're also testing my memory, but I don't believe the R33 has a cold start valve, it just has the IACV doesn't it? That second smaller port on the IACV itself from factory, goes down and under the inlet manifold, but I can't remember what it plumbs to.
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
