Mugabetown - Whoretownin' At It's Worst.
Just no, Sean did not manage his workload well coming into two major events but he would not send an ECU back to Haltech to buy himself time.
More accurately, telling the customer he has sent the ecu back to haltec when in fact the ecu is still in the car ;)
Yes, are you sure you want to accuse a business of somthing that you have no real information on?
A call to Haltech would clear the whole thing up, In fact, Ants if you are reading do call Haltech and make sure they dont drill a big hole in your ECU, they have form in that regard.
FOOOD!!!!!
Early lunch, was dying, needed food... 18hrs with no food is way too long!!! (Ate dinner with a friend with kids last night so it was like 5:30pm)
On the plus, fed so mood has improved yayyyy
I never accused a business of anything, just reading between the lines...
I have absolutely nothing against Sean and or Whitey (if he is still a part of EFI or whatever they turned/merged into???), they have always been very helpful to me and I continue to recommend Sean as a tuner where applicable.
FOOOD!!!!!
Eat a snickers. You aren't yourself when you are hungry
Pretty much! I get Hangry for sure!
You know those hungry screaming children at the supermarket, I am like those but taller and more offensive language depending on the level of hunger and where you shop...
i think you should marry me!
If they have always been helpful what leads you to beleive they would do what you claim they have done
bs been working...
Legit, I was doing staff development forms and shit.
Yes...they like them some drilling
FOOOD!!!!!
Were you Hangry? (hunger induced anger)
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
