Mugabetown - Whoretownin' At It's Worst.
you know what i dont get!! is why they havent made GIANT milky ways! they are like the best ever!!!
Or white chocolate Mars Bars :wub:
i think you should marry me!
Bearer of bad news again, ZCR got in first, soz bout that.
Sup foools?
Eating, Whorin, the usual.... Oh yeah, working, right...
Were you Hangry? (hunger induced anger)
Extremely!
guess ill just have to sweep you of your feet when im up there.... :P
Have to sweep Zane off his first!
Who does she turn into?
The hulk... But pink... And I glitter bomb EVERYTHING!!! However just as angry...
Yes, are you sure you want to accuse a business of somthing that you have no real information on?
A call to Haltech would clear the whole thing up, In fact, Ants if you are reading do call Haltech and make sure they dont drill a big hole in your ECU, they have form in that regard.
Just spoke to Haltech. They have not received any ECU from EFI Performance or under the name of Sean Ramsdell.
I asked them about the drilling of holes in ECU and they told me that they only do that to demonstration / display versions for dealer workshops to ensure they are not used again in the event they are stolen.
He ensured me that they will not do that to mine (if its there)
Really, really, really, really depressed with everything regarding the car FTM.............................to the point where I feel it just wasnt mean to be :/ :/ :/
The worse part about it is if the Haltech is fked, Im not in a financial position to purchase another which means no car, no tuning................................nothing.
The worse part about it is if the Haltech is fked and Im not in a financial position to purchase another which means no car, no tuning................................nothing.
dude ill lend you my adaptronic if you want? my car is in garage not being driven so you are welcome to use until u get sorted
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
