Mugabetown - Whoretownin' At It's Worst.
I would love to see a 20 plus people run
Yeah good really busy at work we are backed up for like 2 weeks :/
I heard about the car. Really not good starting to give me the shits now. I want to see that thing on the road!
First time around those road and I think I kept up ok
Bad things happen there with large groups. In around 2004 / 2005 there was 'fight club' where lots of mountain running occurred. Things got a little crazy and the also the cops started to love it, and this was when cops were far less savage. You would be far better off keeping it to 5 or 6 select cars and having inconspicuous fun.
I would buy the dispenser but the beer choice is shite man.
Chancer is good. And they are planning to expand the range. But it's a lion Nathan product so you won't get any imported stuff.
I like it. But knowing my bad luck surrounding imports. Something would no doubt break so it would not be driveable for a very loooooooooooooooong time
Morning.
Feel like sh!t
Not enough sleep :(
Ditto this, however I have no reason for not enough sleep other than my body hates me - You are waiting for your wife to pop that would cause me not enough sleep (combined with late sleepy time)
Your luck isn't too bad. Every build goes like this! There is probably a few little gremlins left yet, but you are going well tackling them as they come along.
Knowing my luck I wouldn't have picked it up yet and already being pulled over so have no balls to drive anywhere, got RBT'd this morning on my way to work I get pulled over for RBT's often enough the officer said hello again Melissa before I got my licence out then proceeded to tell me he hasn't seen me for a whilst :unsure: Yeah because you pull me over often enough to know who I am just stop me at the mall next time and get it over with... Hopefully this isn't the start of my next RBT record, 10 times in 9 weeks so far which was earlier this year.
lo poor Mel. Looks like da local boyz in blue are attracted to ya. Next time just say to them that u have been drinking, just robbed a bank, and that this is your getaway car :P
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
