Mugabetown - Whoretownin' At It's Worst.
the main difference is the map sensor.
newer gen vipec runs a 3 bar map sensor vs links 2.5 bar.
that was it for the differences afaik, and if you arent looking to run more than 30 psi thats all good.
From the web site it also looks like the Vipec has knock control built in where as the Link needs the knockblock add on?
And isnt it 20psi for the link? Because you have to take away 1 bar for the atmosphere?
I recent acquired a link cheap so I didnt research as much as usual so have some questions from someone who has used them!
as i said, 3 bar absolute vs 2.5 bar absolute (so take 1 bar away from both to get positive pressure)
Hatlech doesnt have knock control does it?
What model did you get?
I see, now I am on the same page
sending you to swim with Sharks :dry: eh!
kinda tells me they wanna get rida ya :devil:
Lol nah they like me too much, I deal with the people they don't need to lol
Swimming with sharks is like getting something out of the bottom draw in from of a seedy old man.
You feel safe, until you leave something exposed
This is very true, I'll either get eaten or speared by a stingray haha
they are a nice ecu and can do lots of nice extras, flat shifting and igition retard launch control provide pops bangs and stationary flutters/bov
ie, sitting at the lights clutch in, revs up, turbo spools, left off throttle. aww yea, 20 psi sitting still.
also they sound awesome with the antilag on.
whos car is this?
    • Yeah do that, it’s only 120kAUD!!! You should have that sitting in the ashtray
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
