Mugabetown - Whoretownin' At It's Worst.
Morning all
I imagine he starts work obscenely early tomorrow.
Bingo, up at 4:45
Engineer me thinks
Yep
bet ya he's on da big bucks. And he's smart enough to invest it rather than spend it.
I'm saving the lions share, but that's not to say i'm living like a monk either.
Investing the savings, on the other hand, needs more work
Soooo much progress for the charity cruise last night. All will be released on Wednesday. My rad hurts from progressing so far. :(
Good to hear!
Now just make sure you run it during my RnR...
I submitted QLD registration form, but haven't received a response email with pymt details.
Is this usual, or should I complete another?
Just checked google drive and your application is there. Were currently going through a change in the membership secretary role and Martin (the old guy) has been pretty flat out.
Someone will contact you shortly.
Morning all
Bingo, up at 4:45
Yep
Good to hear!
Morning Pete! 8 December for charity cruise mate. Got a pretty great route organised.
Morning all
Bingo, up at 4:45
Yep
Good to hear!
Hi Pete, what type of engineering work?
Thanks for following this up :)
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
