Mugabetown - Whoretownin' At It's Worst.
No, bad zac.
What you should have said is "What up bitches." after that proceed to not care at all about whats actually up with any of the aforementioned bitches.
shut up tityboy!
Seems like a lot.
I wouldn't be confident in it lasting any significant amount of time, especially with the Power FC in control
Tis a lot of money hence low ball hat. Im also in no rush to buy so yeah. 8k difference for a fully rebuilt one vs one with bolt ons isnt a bad deal.
This is true
Step 2 in my plan has been completed.... I can hear the rb fanfags crying from here :devil:
Ants just made 470whp on a run in tune, Scott is Likely making 600-700whp as we speak, aint no body crying...or indeed interested :P
Edited by Bunta
Well that's good then :)
You have fun over there with your broken ass 32
It aint broken, its just not making as much power as it can, which incidentally is still much more than you :P
WAIT, were you not having a cry the other day about yours being broken??! ha ha
$2 rubber seal needs changing in the radiator bung I guess ill just have to scrap the car...
I'm glad your making so much power
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
