Mugabetown - Whoretownin' At It's Worst.
I see him trawling this thread as we speak :yes:
Interested to see what results we all get. There is another guy on here that just got his results back on a very very similar setup to what mine is. It made 480rwkw's on 27psi. 6466 with .84
Was he running E85?
Yep..
Here is all is....
That was my car.
Couldn't go past 27 due to needing to up the breathers on the rocker covers and mainly from frying tyres on the dyno
My main thing was that i wanted it be strictly streetable and wasnt fussed about the dyno figure - not that its too bad at all! Therefore I went for a 6466 with .84 twin scroll - I was concerned this would be too big as I was thinking to go for a 6266 originally - although very happy with this setup which is super responsive compared to most cars I have been in, not to mention torquey-as down low due to the RB30.
It has been running for some time on 13psi run in tune which it did 308rwkw on pump 98 - then 20psi on e85 which it did 365rwkw for about 2 weeks.
Even on 20 psi the car is a wild drive on the streets - stepping out in 4th gear once is hits about 4000rpm as if it was second gear (still waiting on half decent tyres to show up).
If I upgrade the catch can (which is small as I wanted it to be hidden) they could push 34psi but doubt I will ever need to, nor bother going to the troubble as this thing has been in the making for over a year now!
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
