Mugabetown - Whoretownin' At It's Worst.
Off to brissy to pick up Stage 2 :ph34r:
Dont be "That Guy" Nick!!! Spill he beans
We could do tomorrow arvo? Around 3?
Cant sorry, booked up with house hold chores in the arvo? Missus has me on yard duty
Im beginning to get that feeling... Feel free to PM me your idea/stage 2 plans
You know considering im so open and sharing about mine!
Bahahaha, it's all good mate it'll be going up in my build thread but only piece by piece
I see him trawling this thread as we speak :yes:
Interested to see what results we all get. There is another guy on here that just got his results back on a very very similar setup to what mine is. It made 480rwkw's on 27psi. 6466 with .84
huge numbers that is...........huge!!!
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
