Mugabetown - Whoretownin' At It's Worst.
Off to brissy to pick up Stage 2 :ph34r:
Dont be "That Guy" Nick!!! Spill he beans
We could do tomorrow arvo? Around 3?
Cant sorry, booked up with house hold chores in the arvo? Missus has me on yard duty
Im beginning to get that feeling... Feel free to PM me your idea/stage 2 plans
You know considering im so open and sharing about mine!
Bahahaha, it's all good mate it'll be going up in my build thread but only piece by piece
I see him trawling this thread as we speak :yes:
Interested to see what results we all get. There is another guy on here that just got his results back on a very very similar setup to what mine is. It made 480rwkw's on 27psi. 6466 with .84
huge numbers that is...........huge!!!
    • did you go to the us gtr festival? any progress on getting the car back out and running?
    • I had some time over the last week  and decided to test if block filler will hold the blocks shape similar to a torque plate after the head has been removed. 1, 3 and 5 were measured at 9 points each before and after. MY goal was to see how much impact a torque plate has on the shape of the bore. The first set of measurements were taken with the main girdle and head off with no filler. The block was then filled with grout up to the water pump (half fill) and the girdle and head were torqued to spec. The block sat leveled for 7 days and was disassembled. The second set of measurements were then taken. Results are presented as the delta between the original and new value. All values in the PowerPoint are presented in inches because America. The largest changes were 0.0035 in or 0.0889 mm between cylinders 3 and 5. There may have been even greater changes if the block was filled to the top with grout. I hope this information is useful and I'm curious to hear what you guys think.       Notes: My block had the most wear in cylinders 3 and 4. Due to the amount of change in 3, I measured 2, 4 and 6 separately. 4 was also all over the place. 6 was similar to 1. They were not included to keep the test objective.
    • I also find it hilarious, everyone thinks chop idle tunes sound cool, and they do... Because they sound like an angry rotary engine idling.
