Mugabetown - Whoretownin' At It's Worst.
Fk financial advice most people would say I am a terrible person to discuss financial advise with but the way I see it I am a problem solver, something goes wrong I find a way to fix it, same with money. When shit hit the fan with my douche of an ex I had near on 65k of debt for shit we had that he kept (inc. 2 cars and a dirtbike plus c/card crap) 4 years later its down to 15 plus I have paid off an additional 15k cash in education expenses over the last two years on top of my hecs - Then people wonder why I work all the time and have no money. Debt sucks and the only debt I look forward to is a house, I learnt the hard way! But knowing I can pay all my shit plus save for a wedding, pay rent, groceries for two and all the house bills whilst the other half hordes money for a mortgage is well worth the amount I work! How do I do it? I am insanely organised to the point that I often freak myself out that I have forgot something but it is just that I am that organised...
However if I don't give a shit I am not organised at all...
Disciplined :)
Haha not the right word for me, I problem solve - Really want those shoes really can't afford them, wing it so I work more that week to get them...
That's even more disciplined. In management terms they call that Locke's goal setting theory. Essentially you set waypoints to getting things you want to achieve. They have another acronym too called SMART
Specific - there is a precise and clear statement of intended outcome.
Measurable - there are clear indicators (quantitative or qualitative) of whether goal has been achieved.
Achievable - The goal is achievable, within available resources and environmental constraints, and is compatible with other goals that have been set.
Relevant - the goal is aligned with broader goals, values and priorities, which provide a rationale for the goal.
Time-bound - The goal includes a statement of precisely when it is to be achieved.
Winning Mel :)
Mel, if you've managed to affectively clear 65K (50 in debt 15 in education) in 2 years, I wouldnt say that you're bad with money... I'd say you've got it quite well managed at the moment.
Oh an Tim... Do you happen to have a spare R33 GTST S2 bonnet you'd part with?
I didn't get one with 2nd car - had to negotiate that out, as I had Titans. I can get you one pretty cheaply though, or a GTR one if you'd like they are significantly lighter. PM me for details.
No all pretty good
Just a little bit of carbon build up, looks like it was maintained well
Ok so question
If Kathryn gets this na 33
Should I take the cams and injectors from the rb25 I just picked up and put them in hers or are the cams the same
I Know the inj's are a good upgrade
No all pretty good
Ok so question
I'm not sure about their compatibility, as I normally upgrade with aftermarket stuff. I am guessing, but there may be a difference in the engines compression ratio (piston tops)and there would most likely be stronger valve springs in the turbo motor, also the valve seats might be different. inj shouldn't be a problem. According to Wicki the bore and stroke is the same and the cams are the same duration and lift between the motors, accordingly no benefit from cam swap. http://en.wikipedia.org/wiki/Nissan_RB_engine
Also, sounds like you sourced a really good RB30 engine. :)
I wouldn't swap cams.
NA and turbo engines run a different profile for a reason.
Injectors, will it need extra fuel? What're you going to do to tune it? What mods to require more fuel?
Tim PM incoming on 2 different topics
Ok guys so if all goes well on Saturday providing Ben can make it and I get his 31, my goal is to have it on the road for charity cruise the only bad thing that will hold me from having this happen is being broke as a bum
If you get the na, don't go sticking turbo bits in while na.
Turbo cams and na cams have different profiles because they benefit from the cams have more or less overlap depending on desired application.
If you get any mods for it keep them basic as they arent worth much when sold and will cost significantly more than just buying a turbo one to begin with
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
    • Good news mate, plenty of spares available 5:40
    • What I’m saying is that I never heard of a non gtr 34 coming with a cooling panel stock or factory option. Maybe they might’ve I don’t know
