Mugabetown - Whoretownin' At It's Worst.
Manuals are evil
No
Gladly, yours would no doubt pay a fair bit better than mine
Yes but it can be a shitty job
And slow ;)
No
well see about that uncle Natro
This
Only time an auto should be in a jap car is if its a 2 or 3 speed and used for racing.....
And this
Trannys are good - I love me some Trannys
FYP
Going to be keeping all the associated turbo parts off the 25 skyine incase s*it breaks
Suggestions a for turbos for the dirty? Don't know whether twin or single
Something that's 300 to 350kw max, more than that is fairly unusable without big $$$ tires and borderline too laggy for daily use.
A gt30 with a .82 rear will drive almost as nice as a stock turbo 25, just that it has 300kw instead.
I reckon if you go to the trouble of building a 30/25 then you should choke it up with a small turbo like a GT30.
To get the true benefit of the change I reckon a GT35 or larger is a must.
In saying that Ive never been in a 30/35 running a GT30 variant so not sure how it would drive
Inestment home or residence colin?
Still undecided yet. Its nearly 1k a week rental at the moment so it will be tough to let that go lol. Would still get decent rent if we lived there and rented a few rooms but we dont know yet.
Yeah Ants capt barrel roll is me so wanna get into another one
i had a 35 on mine, too much power for daily duties and enough power to make it about as reliable as a rotary. power came on hard at 3500-4000 and insta wheel spin on anything short of near new 255 semi slicks.
a GT30 with 0.82 would give near on stock turbo spool, but an extra 100kw, a 1.06 rear would tame it down from being so agressive onto boost, but obviously that comes with more lag.
GT30 size turbo is the SMALLEST you can go on the 3L without choking it.
check out the results AL from victoria got with his 3L with GT30, decent power/torque everywhere and the benefit of being able to keep it looking mostly stock if you wanted to, if i was to do my car again. thats the combo i would go for.
Guess mine will be interesting to steer then lol.
I'll have a look for those results. can never look at too many :-)
Congrats Col, I looked up 5 bed townhouses, I think I found the ad. Looks nice! If you are getting the stamp duty concession you need to live in it for 1 year with occupancy starting within one year, and renting out rooms counts as you not occupying it. Something to keep in mind!
eggszachary
these results. i believe the full specs were somewhere in a mountain long thread. but it was from memory it was running a 9:1 comp ratio with some minor head work.
Just realised that i haven't updated my results.
Officially the engine is now out flowing the turbo, but i will not change the combo for anything.
Below is my full tune as it stands now.
The car has been booked in for next week to get the following done:
- Change exhaust and see if any gains are made. Currently i have the more quiet exhaust fitted and would like to compare this result with the Apexi cannon exhaust system i have laying around.
- Play with my cam gears. I still have VVT active, but have modified the std gear to also be adjustable.
- Clean up the afr. Dips too low up in the higher rev range.
- Play with the boost settings, to come on harder on high boost.
- Most important: Find a pair of tyres that will hold traction on the dyno. So far i have tried 4 different pairs of tyres and all have lost traction on full boost at high rpm. I have tried: Hankook K104's, Bridgestone RE55s, Toyo T1R's and another pair of cheap ass tyres from another 33. Anyone know of a good pair of dyno tyres????
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
