Mugabetown - Whoretownin' At It's Worst.
Ahhhhh the stealth approach, very sensible. I still haven't managed to come around to this approach - I actually enjoy arguing the police powers and road traffic act with the 50 :)
Life's more fun with a loud exhaust.
Worry about that when the time comes, the likely hood she'll keep it and do the swap is low (sorry kat but the odds are against you keeping it)
It takes a very very strong bond with a particular car to want to drop money on it when you know there is a cheaper route
It looked pretty clean in the photo Nick, if the car is straight it's worth keeping and just getting engineered. The shells are the same, it's really only the numbers that aren't.
Mine has a dint where the rear right hand pod goes, other than that it's straight. Seriously want over fenders thinking more and more how cool they look lol
Michael that is seriously worrying lol I now rank that in the same category as the gold shorts package I saw yesterday lol
Mostly because she loves taking it hard but she also has some problems...like rust.
Tunnels/mountain cuts especially :D
Got told my car didn't sound like a commodore yesterday, I guess that's a good thing
Tunnels...clutch in...rev-limiter...
It's still a commodore at heart.
You sure? I'd be checking that...
I assumed P platers can tow trailers, I'd check that as well.
You should be able to drive it to the nearest place for the purposes of obtaining registration.
This is correct, just organise CTP first then you can drive it to get a RWC then to the nearest Main Roads dpt.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
