Mugabetown - Whoretownin' At It's Worst.
I might pop down late this arvo in a hope it's on the rollers
Yeah.
I don't think it is my coils, I took it for a drive and no issues at all under any load on the factory ones yet when I free rev it around 4k it starts breaking down same as it did with the yellow jackets last night.
I am starting to think it may be over fueling when no boost is being fed in while free revving.
Put the boot into it on the highway and she goes like crazy with no issues exactly the same as it did on the yellow jackets before servicing.
Morning Mangs, got the car up and running on factory coil packs, I took it for a drive but I have not free revved it like I did with the other coil packs.
I will take it for a good drive and see how she goes. May be time to order new coil packs
:) check below
Yeah.
If the only thing moved/disconnected was coil packs to change plugs then it is typically coils. if not, Check leads next, if not then igniter might have a fault.
Just checking with this question, did you change the timing belt/move sensor to do so?
Yeah.
If it's breaking down UNDER LOAD then it will be coils or there abouts... If it's only doing it when free rev the you could have another problem like you said...
Morning all
Morning mate
Sounds like a good plan
Igniter is in the coils, does not look like loom or coils TBH they operate under load and at speed, not plugs either.
Background on the car:
400rwhp r34 gtt
never had an issue with missfire ever
109000K's
only missing at revs while free revving
no issues under load or at max boost (23psi)
Edited by RandomHero83
I've currently in the process of increasing my curling weight from 15kg to 17.5kg. For the last week I've been doing a set consisting of 8 reps on 17.5, 10 reps on 15 then finish with 10 reps on 12.5kg. That's my super set, I take a 1min rest between these sets and do a total of 4 sets.
Can't lift even an apple afterwards
Yep need a straw and a bench to drink water lol
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
