Mugabetown - Whoretownin' At It's Worst.
Zac is a top bloke, went down and found that I need:
Rear main seal
Top radiator hose - Got this thanks to Zac I will fit it when the car cools down.
Gearbox leak fixed - little leak @ the back.
Cold motor was the cause of the missfire I will run the factory coils until I cbf swapping the yellow jackets back in again.
Rear main seal
Zac our trusty little handy helper :)
Great to hear mate. I'm pleased to hear it wasn't anything major.
Means you can have a bit of driving fun once repaired ;)
Oh and Clint, with that hose fitting just make sure there is no crap on it and no coolant is on that sealant
It's ok if like a drop or 2 but it's best to have it clean
And let that sealant sit with the clamps on for a good hour before any coolant is put in the system, just for the extra sealing strength
Didn't stop me from having driving fun, was being gentle on the way home though.
Could of been really bad so big thanks to Zac.
Aye will do, DOn't need to drive it again today.
Will head out in the next hour to sus out the car situation
Let me know if you want company
Would u like me to keep this for you Clint just in case u need a replacement straight pipe?
:P
May come in handy.
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
