Mugabetown - Whoretownin' At It's Worst.
Have you modified anything on the car zeke?
Or is she stock at the rock
FMIC, pod filter, boost tee upping it to 10PSi, spark plugs are gapped to 0.8 instead of 1.0. 18x8 wheels, 3" Xforce zaust with 3.5" tip, 200CPi metal venom high flow cat.
Old man's commo blew a heater hose off the valve today...farking commos breaking. It split its radiator about 6 months ago, looks like Holden wants them to destroy their cooling systems and overheat.
lol u been given it some boot Mikie hence why breakin :P
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
