Mugabetown - Whoretownin' At It's Worst.
Made some weird noise waiting at the lights like something bad broke then proceeded to drive with a horrible miss
Checked over it at the local servo couldn't find anything and car would start and run but has a bad miss.. at first thought it was the turbo shat itself out the exhaust but still makes boost...
im thinking ignition problem
But if u heard something break........that's not good.
Fouled spark plug
Check over all the connection people forget that they're all 20 years old and brittle so they easily break. Doesn't explain a Lou noise though :/
Nick has a valid point here - could also just be hose that blew off......
Yeah hopefully it's just the copper plugs I been running for far to long and not something else.
only one way to find mate - x fingers its only minor repair
Sitting idle at the lights is when it started revs where under 1000rpm
Get missfire under 3k when causing at 100km/h it seems all fine :/
When I get home I'll pull the plugs
Btw I am running splitfire coil packs only about 4 years old.
Have to get technical on this stuff.
Any description is better than a something is broken noise. Can't be that bad of a noise, otherwise (I) would not be driving anywhere after hearing it.
BTW, 3 zeds in shed. 2 engines out.
Edited by MagicMikeZ32
What kind of noise did it make? Crack, bang, mechanical metal on metal or something else? Whirr?
Bang but metal on metal noise but like a rock bouncing under the car.. first though was it's someone else's car but I did feel it in my feet..
When I took off it blew 1 puff of white smoke... not sure if it was my car or another car as it didn't do it again for the rest of the trip to work.. only thing is the big missfire
First thing I'll do is check the plugs
I pulled in to the servo up the road and checked everything I could and all looked and sounded normal... The noise before hand could be irelavant but seemed to happen at the same time it decided to run like shit
I'm inclined to think that its not irrelevant and that they are somehow associated with one another Ed.
Whenever a bang happens and then the car runs like crap - I think its rather important to find out the reasons for the cause so you can rectify it, otherwise you may think that all is well and continue driving the car until the inevitable happens.
Get to it before it gets to you.
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
