Mugabetown - Whoretownin' At It's Worst.
2 sets, no leaks etc.
1 set JIC Magic, quality jap gear. Hard rates tho, perfect for track work or mountains. Think they are 8 and 10 or 7 and 9.
1 set Tein SS, better for Brisbane shit roads.
How much are you chasing for the Teins?
Motherf**ker
My brand new second hand raw broker CAS is dead
Just swapped it back with my old one that's stuffed and is idling like normal
Fu$k
Beer time
yeh at least uve located the problem Ed.
I have a spare one here for 20?
if it works i will take it! thank you :D
really thought i would be over CAS issues since buying a refurbished CAS (all new parts inside apparently) but guess that is a risk you take :(
yeah this CAS are a pain in da ass.
And not cheap to replace if buying new.
I f**ked mine up once and was lucky to be able to source a second hand one that has not given me any issues
yet
White 1995 model v-spec
Also has
Hks oil cooler
Unfortunately, with the motor on its way out you would be looking at the same amount as the lowest trade in value, namely, around $11,800. You may be better off parting the car out, if you have the skills/time to do this yourself. http://www.redbook.com.au/cars/research/used/details/1995-nissan-skyline-bcnr33-111628?R=111628&Silo=spec&Vertical=car&Ridx=9&eapi=2 To get the thing back to where it needs to be with engine rebuild and other repairs would be around the 15k mark as a rough estimate depending on how bad it is.
Another benchmark car is a 1996 bright green skyline GTR V-Spec with all the fruit, but some interior and bits missing for $11k. It has been on the market unsold for quite a while http://www.gumtree.com.au/s-ad/mount-warren-park/cars-vans-utes/1996-r33-gtr-nissan-skyline-v-spec-repairable-write-off/1031209389
yeah already know about it
Thanx for the link.
But justifying the price for that kit is pretty hard to digest
So, this was my car on Monday....
Luckily, the hail was just sliding off the edge of this, no damage caused
It did have this cool aftereffect, i really wish my parents had used the good camera to take this one.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
