Mugabetown - Whoretownin' At It's Worst.
well if u do.......make sure you hit a few for me as well ;)
And me, always loved smacking 7-8-9 irons, and when you hit that sweet sw shot and it just sits when it hits the green.... Sah nice
And then comes the dreaded short game :rant:
I thought you stopped posting, as your keyboard was clearly bigger than everyone else's. :) Balance is critical. If it was so simple, why didn't you make one up yourself???
PS: I am actually fully trade qualified (Ask Ants) and build RB engines myself in what little spare time I have outside law. My latest build is 390AWKW SAU member's engine. Have you even touched or used the Ross trigger system, or just posting that they suck for the sole purpose of trying to contradict me? :)
Notice I put smiley faces, therefore it's a friendly post. :)
I didn't make one my self because a monkey with a cnc machine can make a prefect trigger disc in minutes. I don't give a f**k if you are qualified in every trade ever and made a 9000kw rb in your kitchen, you are wrong. There is nothing difficult about a crank trigger no matter which way you slice it, any machine shop in the country can produce the required disc. I have touched a Ross kit. Then used it to think of something else that does the same job for 1/4 of the price. At no point did I say the Ross kit is shit. It isn't, their price however is completely unjustifiable for the simplicity of the gear they supply.
I got my information on how to get the set up done simply and cheaply by a guy called Alan Heaply who also knows a thing or two about RBs. Probably even trade qualified but I would have to verify that with Ants.
CAN WE ALL PLEASE PUT OUR EGOTESTICAL BEHAVIOUR TO ONE SIDE!!!
IS THE ROSS CRANK TRIGGER KIT DURABLE AND RELIABLE – YES
IS IT EXPENSIVE? – WE ALL AGREE THAT IT IS
ARE THERE ALTERNATIVE SOLUTIONS AND CHEAPER CRANK TRIGGER KITS AVAILABLE – YES
I AM NOT VERIFYING ANYTHING EXCEPT FOR THE LACK OF RESPECT PEOPLE HAVE FOR ONE ANOTHER SOMETIMES
NOW, ENOUGH OF THIS HIGH SCHOOL BEHAVIOUR AND LETS BE SINCERE TO ONE ANOTHER AND HELP EACH OTHER OUT INSTEAD MATURELY
do you need a hug ants?
In other news, Ashes have started and Australia has chosen to bat first.
Now, can Australia maintain their 25 years test winning streak at the Gabba? Or can England make this Australiá's 10th test loss in a row?
  • Like 1
I don't think we will lose, the test series over there was pretty close, and this time its here, and we have a better team.
IS THE ROSS CRANK TRIGGER KIT DURABLE AND RELIABLE YES
IS IT EXPENSIVE? WE ALL AGREE THAT IT IS
ARE THERE ALTERNATIVE SOLUTIONS AND CHEAPER CRANK TRIGGER KITS AVAILABLE YES
  • Like 1
Big man hugs all round
And I think we will lose again. Maybe not in Brisbane, but we will lose the series.
Stupid Poms.
Stupid Clarke.
Edited by MagicMikeZ32
Ross can eat a dick. The price of those kits is Bullshit. I got my gear from some local guys who were able to provide the trigger, hall sensor and mounting kit for less than 400 bucks.
Hmmm slight contradiction on the Ross front, but you seem like a pretty complicated guy lol
Here's the killer for your argument about how a simple monkey can make it... Nissan couldn't get it right - Feel free to verify with your best mate Richard Cranium :)
For anyone who is interested, I exclude you Bunta (because you're such a knowledgeable guy) - Have you ever tried to bend a pen? If you hold it midway... it doesn't work but if you lengthen it and support it at the quarter way mark then the pen bends/wobbles... now if you add a trigger wheel to the front of the crank to extend out the front what happens?????
That's the best you got... is the guy clever enough to hold a law degree too - again ask yourself :)
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
