Mugabetown - Whoretownin' At It's Worst.
I know that there's some 80 year old guy in England who has about 12 different degrees, and even a few doctorates in those fiels. Obviously he has the superior knowledge of RB engines!
Depends if he is trade qualified and builds RB engines also?
So using your thought process, wouldn't an opinion from a qualified source be more plausible than an opinion from a less qualified source?
And what subjectivity is offered to the comparisons of level of qualification? Is it proven academic results, real life results etc?
In which case, and adopting this logic, I get my info from my brother in law, when I need it and he balances some of Sydney's biggest hitting Skylines. Also John Skola - ex Dick Johnson Sierra days engineer. Their penises are definitely bigger lol
Function is form.
I'm failing to see the argument here. Bunta cited Alan Heaphy, who built one of the most famous R32 GT-Rs in Australian motor racing history. Wouldn't his feats demonstrate his knowledge on the topic?
Australia - 1/42
  • Like 1
Function is form.
Ohhhhh, Like in this instance, you would need to show a crank trigger and mounting kit produced easily and cheaply by a local machine shop. Now if only I had done that already! Damn :(
Can I just say that I have no qualifications?
Got a phatt stack and some epic wide wheels tho ;)
And a big shed. And really, that's all that matters :P
FFS peoples, let it go please.
Buy my parts
  • Like 1
Wow...
Sooo, I bought lights yesterday... And I now have a house with doors and windows, no bricks but still... It's like Bear in the big blue house with all that insulation wrap stuff...
Buy my parts
You also have a hoist in the shed, two zeds a lovely wife, awesome house and two adorable puppies. Your cat scares me.
Australia - 1/42
It's a bit old hat. The technology has moved on. They make more power now. Kind of like Mike Vine used to make the best manifolds.
See this:
http://www.justenginemanagement.com/index.php/customers-cars/nissan-rb-power/44-gibson-gio-r32-gtr
And now the power figure on this:
http://www.justenginemanagement.com/index.php/customers-cars/nissan-rb-power/1-110826mohpwr
Did I mention both Adam Neish and Bobby are good mates ;)
I have multiple qualifications yayyy!!
People still think I'm fkn retarded tho because I suck at simple shit like... Left and Right or don't touch it, it's hot...
Perfect example, yesterday I discussed our electrical plans and quotes and contracts and timeframes and the banks requirements and everything else with with the lighting supplier and then Zane had to tell me how to open the door to get out of the shop *facepalm*
Because female.
:P
Lol!
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
