Mugabetown - Whoretownin' At It's Worst.
Who wants to sponsor me? Want to buy a brand new CAS from Nissan. Really don't want to play the guessing game with another second hand one.
Gus Oberhardt on facebook was selling one a week or so ago. Few months old, I think he said 4. Wanted 400 bucks for it. The rb26 and 25 one are the same I think?
I have another second hand CAS lined up with cowdy.
Just hate the things as it will be the 4th CAS to go onto the car and would be easier to get a brand new one but at over $600 I won't be getting one anytime soon :(
4 CAS units? I suspect something else might be at play
I have had 3..
First one on the car died
Second Hand one never worked from when I got it but as I had other issues didn't know it was stuffed
Third one that was Second Hand reconditioned capped itself....
I guess it could be something causing them to died or fail where my car runs like crap.. I am back on the second CAS where I have a miasfire under 3k which is heaps better than the reconditioned unit
positive, swapped between CAS i have and both run differently the one i went back to and currently using runs the same it did before getting a newer one..
Sure it isnt the connectors?
Thinking about buying one of these http://www.ebay.com.au/itm/CRANK-ANGLE-SENSOR-NISSAN-Skyline-94-98-R33-2-5L-6CYL-J926-CAS-ONLY-RB25DET-CAS-/131008368517?pt=AU_Car_Parts_Accessories&hash=item1e80b50f85&_uhb=1
I thought my cas had died at one point, it was a faulty wire in the loom that needed to be cut back and replaced, worked flawlessly afterwards.
If the car changes between running fine and running funny while playing around with the cable you could have the same issue.
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
